    One or more buildings
    Scheduled Pinned Locked Moved Google Earth
    4 Posts 2 Posters 8.9k Views 2 Watching
    • T
      ThorOl
      Hi fellow sketchupians.
      I am about to model this building in Norway:
      http://tinyurl.com/cncqch5
      My question is, would you do this as one, or more buildings for google earth?
      • GaieusG
        That's a whole block. According to the SketchUp to Google Earth modelling guide lines, each building in the block should be a separate model to submit.
        You can model them together however (best practice to keep the buildings perfectly aligned) but make each building a separate component. Once done, go to the Component browser and right click on each component (the whole buildings only, if you use nested subcomponents) and "Share component" from there. They will now be shared and uploaded separately.
        • T
          ThorOl
          Thanks!
          One thing tho, that is not very visible from the photo. The "Center" of this blosck is raised. The whole inner of the block is raised to a second floor. Does this change your previous answer?
          • GaieusG
            Well, here is the guide line for the individual buildings:
            http://support.google.com/sketchup/bin/answer.py?hl=en&answer=1267399
            Then you can also add a (small) "terrain skirt" (which I would use for that central area if it is only raised and not a building like a garage):
            http://support.google.com/sketchup/bin/answer.py?hl=en&answer=167465
            But make sure that small is small. Like it should not extend out of the yard in your case, I guess. Here is the guide line:
            http://support.google.com/sketchup/bin/answer.py?hl=en&answer=1267403
            And all the guide lines:
            http://support.google.com/sketchup/bin/answer.py?hl=en&answer=1267260
