    Automated Excel 2 SketchUp PLUGIN
    35 Posts 28 Posters 147.2k Views 28 Watching
    • duanekempD
      duanekemp
      Can this be used to select/deselect layers on scenes?
      For example: Keyframe animation of 400 frames at 25 fps. Animation is perfect. I want to add a blinking light on/off every half second. Can this be used to add that light component on/off to a group of 14 frames and off for 14 frames via this type of programming?
      Duane Kemp
      Kemp Productions
      Puidoux, Switzerland
      Gallery:
      https://duanekemp.artstation.com/
      • D
        danxx
        I would like to see this in action on 2015. Can I contact the author. please email me on mr.dpg[at]virgin.net
        • aadbuildA
          aadbuild
          Hi guys this is cool. We just added excel export to Plusspec. There is a webinar on tomorrow at http://www.plusspec.com of you'd like to check it out.
          Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
          https://www.plusspec.com
          • U
            unearthed
            Great work Faraz, Can't wait to see how it runs
            Growplan - People ∩ Plants ∩ Place
            windows 7 64b, 4GB RAM, SU 8.0.16846
            Gimp, QGIS, Vectorworks 12, Bricscad 11
            • M
              mgsvinc
              Hello, i would like to use your plugin to control the positioning of my models.
              The objects remain the same (there is no change of dimensions within those objects), the only values which I want to pilot from Excel are the positioning of these objects.
              Could your plugin help me do this ?
              If not, do you know a way to do this with your plugin (maybe by modifying the code)?
              Or even better, do you know a plugin that can do it ?
              Thank you for your time and for your work.
              • S
                Sekar24
                Hi, I am unable to use, as there was no menu in su 2017
                • J
                  jackmartian Newcomers
                  gb whatsapp
                  May be I think you can adjust keyframe little bit more instead of 25 fps.
                  • S
                    seosambad Newcomers
                    There are many state sponsored game in India like Kolkata Fatafat and Lottery Sambad .These games are legal in 13 states of India and conducted by state governments. Lottery Sambad is the biggest one of these games.
                    • V
                      vcbhfg Newcomers
                      GB WhatsApp Download is one of the most popular WhatsApp mods for your device. This WhatsApp mod is a multi-account-friendly mod and much more.
                      GB Whatsapp Apk allows users to share their current location with friends. To begin with, you can use the option of automatic reply whenever you wish to respond to friends.
                      One of the most exciting features of GB Whatsapp Latest Version is the ability to purchase and use company-created themes.
                      • P
                        piperthomas4765h Newcomers
                        @farazforoozan said:
                        Domain Specific Tool SketchUp Manager
                        Latest update: 02-06-2013
                        This application is developed for SketchUp designers that want to automate SketchUp through MS Excel. Component data specified in Excel is pushed to SketchUp. After performing scaling, translation and rotation, the component data can be written back to Excel. Previously created shapes can be re-added in SketchUp and also written back to Excel.
                        Application improvements:
                        -Input rotation about the x, y and z axis does not work yet.
                        -Input number of items of a component does not work yet.
                        -Rotation output is still in radians.
                        -Dimension output is still of the bounding box of objects.
                        -Cone input parameters were Dim(y) and Dim(z). Needed to be Dim(x) and Dim(y)
                        -Rotation output seems different than input. I suspect because the rotations are merged in a transformation product and they are performed sequentially and the bounding box transformation object may be different. Performing rotation about x and y axis results also in a z rotation.
                        Potentially added to application:
                        • Cost analysis functionality.
                        • Bounding box envelope
                        • Variable metric system
                        1. Copy all files in the rar file to the plugins folder of SketchUp.
                        2. Open the Excel file.
                        3. Open SketchUp.
                        Sincerely,
                        Faraz
                        Hello, The application is designed for SketchUp designers who want to automate SketchUp through MS Excel. It allows component data to be pushed from Excel to SketchUp, performs scaling, translation, and rotation, and writes the modified data back to Excel. Some improvements are needed, such as adding rotation about the x, y, and z axes and improving the output format. Potential additions include cost analysis, bounding box envelope, and variable metric system. To install the application, copy the files to the SketchUp plugins folder, open the Excel file, and launch SketchUp.
                        • G
                          gbws Newcomers
                          @renderiza said:
                          Hi, currently making a game for SketchUp and I am asking if this could be best solution for storing data. I have yet to workout how to store game stats, achievements & high-scores. Anyhow thanks for posting this I will experiment with it and see.
                          [url=​https://descargarwhatsplus.app]​https://descargarwhatsplus.app[/url]
                          • W
                            wudier Newcomers
                            3. Open SketchUp.
                            Sincerely,
                            Faraz
                            Thank you so much for sharing.
                            • T
                              thomascook Newcomers
                              Does this only work with MS Excel? Or it is comfortable with others. .
                              • H
                                hazle123 Newcomers
                                gb whatsapp
                                • L
                                  LordSweeper Newcomers
                                  It does work with other software as well. But for better and suitable performance I would suggest you to use MS only.
                                  • 2 / 2
