    Match 2 smoothed polysurfaces on border (terrains) -> solved
    5 Posts 4 Posters 421 Views 4 Watching
      Vertex tools has a function to fix small gaps. See this video (at around 4:22 where I actually linked, too):
      • cottyC Offline
        cotty
        Can you upload an image which shows the hidden lines?
        my SketchUp gallery
          @ cotty: what would you need the hidden line for?!
          Maybe for align connections ?
          • cottyC Offline
            cotty
            I thought about vertex tools too, but if your mesh has a high density, the vertices are merged horizontically and not in the desired z direction (perhaps?).
            my SketchUp gallery
            • dukejazzD Offline
              dukejazz
              Hey I found this tool
              Point Merger Tools v 1.2
              (25.81 KiB) Downloaded 1021 times
              I would like to have your example
              but since i don't here
              you can soften inter edges to make two surface of the mesh terrain
              select inter terrain
              max distance of gap
              now it shoud be good
              if the poly code count to high it will also lower the count, then do what I did above
