    Illustrator to sketchup
    8 Posts 6 Posters 2.2k Views 6 Watching
    • B
      bhbarchitects
      Hi All
      Created a pattern in illustrator exported as dwg, when importing to sketchup the external edge of the pattern loses its shapes as if its been oversimplified. Any ideas??
      pattern imported from illustrator
      after exporting into sketchup
      As in illustrator
      • GaieusG
        I do not know Illustrator but it seems you were using some curves there and SU impoprted them with some default settings. Is there any command in Illustrator to explode those curves?
        • B
          bhbarchitects
          Hi Gaieus
          Not sure will have another look through, its appears okay when its in cad.
          • B
            bhbarchitects
            Turns out it appears to be the amount of points in a curve. cropped a portion of the outer path and it imported fine....
            • DavidBoulderD
              DavidBoulder
              Illustrator lets you internally convert curves to segments with more controls (such as length of segment or angle between segments). Do that to a copy of the design in Illustrator, and then export to DWG
              David Goldwasser
              OpenStudio Developer
              • tibetT
                tibet
                sorry to see the same problem, which i´ve too.
                i´m sorry that so excellent program doesn´t support eps/ai/cdr files.
                when i like to import from coreldraw ( in my case) i added a lot of dots,export to *dxf, then fix each object manually with weld plugin in SU.
                hope this issue gets fixed soon,it´ll be a great improvement for sure.
                *i gets the best results by dxftool pro macro for CorelDraw
                SU 2015 Pro on Win10 x64
                  I test the free oneline http://www.autotracer.org
                  from your snapshot image 😄 (not from your SKP because I presume that is V8 💚
                  save in dxf
                  and import in free SU V6 : 29628 egdes
                  fleur2.skp
                  • pbacotP
                    Nice drawing. Wonder if turning it into SU edges is of use. How do you intend to use it? could it be better used as a texture or in post-pro? I assume you aren't going to make it 3d...
