    Merge a road model into a terrainmodel?
    4 Posts 2 Posters 334 Views 2 Watching
    • G Offline
      gesi
      I have successfully imported and created a terrain-model from Novapoint (dwg) into SU (7.1) and I have also successfully imported my road-model from Novapoint (dwg). I'm using the same coordinates from Novapoint for both models so the road is placed in the right position into the terrain-model.
      http://img833.imageshack.us/img833/1783/modelml.jpg
      Question:
      How do I merge my road-model into the terrain so that the terrains surface adjusts around the road?
      Is there any plugin for this kind of operation?
      //Georgi
        here a PDF tutorial about that by Daredeavil
        (sorry in French but with images and you can put the text in the Google translator πŸ˜‰
        • G Offline
          gesi
          πŸ˜„ Thanks for the quick reply appreciated!
          It seems that I'm not authorized to so I cant see the pdf you just uploaded. Is there any other way I can get the pdf?
            Aaahh! Sorry! 😳
            It's because it's on the French Section!
            So the more easy now is to read the file linked πŸ˜‰
            Route.pdf
