Save dialog causes bug splat
Sometimes, when testing my plugin in Windows, it crashes completely as it tries to show the save dialog. It's hard to give specifics as this isn't consistent. In some cases, substituting the save dialog with a messagebox still causes a crash. Are there any tips to avoid the UI somehow causing a crash?
My only successes have been with drastic plugin removals.
Does it happen if you have only your plugin loaded?
Register LoginAdvertisement
