    Print Settings will not save.
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    5 Posts 3 Posters 8.3k Views 3 Watching
    • KrisidiousK Offline
      Krisidious
      Printing to PDF... Not exporting. I have to go to page setup to change the print paper size every time I print.
      How can I set it to Arch D everytime?
      By: Kristoff Rand
      • FrederikF Offline
        Frederik
        I assume this is based on the template you're using...
        If the template you're using originates from i.e. A3 size, you are able to print it in Arch D, but you'll need to set it every time...
        Cheers
        Kim Frederik
          Krisidious
          I don't think that's it... I used a Layout Arch D template and modified to my own.
          By: Kristoff Rand
            Charlie__V
            I assume you are asking for Layout to remember the sheet size?
            For now, set your default sheet size in your .pdf printer preferences.
            (For me I would set Adobe Acrobat Pro print preference...page/sheet size to Arch D and save settings)
            Charlie
            EDIT: And also set your .pdf printer to default printer.
              Krisidious
              I tried that just now and I must have done something... I hit a few options so I can't know for sure what did it... But I lost all ability to print. I have like 4 different printers and it would not print to anything. kept saying I needed to add a printer. finally I just did a system restore back to this morning and fixed it. Now I'm gun shy.
              I'm going to go back now and do as you say and only as you say and then test.
              By: Kristoff Rand
