    Offset a line Ruby command
    7 Posts 4 Posters 5.0k Views 4 Watching
      sachi
      Dear all,
      Does anybody know about a Ruby API command to offset a line? I already checked the API.
      It has a command to offset a point.
      point1 = point2.offset vector
      But i need to offset a line, like a parallel line. Is there any command in Ruby API which i can work with or any suggestions to offset a line(draw a parallel line)?
      please help me, im stuck here
      thank you in advance
      • TIGT Online
        There are several ongoing 'offset' discussions in the Developers' forum...
        There is no API 'offset' method, for edges or faces.
        But there are various scripted solutions.
        If you have one edge, then you are able to get its vertices, from these you can get two points, and then you can offset these points by a vector of the desired length... and then use something like edge.parent.entities.add_line(pt0,pt1) to make the parallel 'copy'...
        PS: I have moved this into the right forum...
        • Dan RathbunD Offline
          Dan Rathbun
          module Sachi
            module SomePlugin
              class << self
              def clone_edge_by_offset( e, vec )
                return nil unless e.is_a?(Sketchup;;Edge)
                return nil unless vec.is_a?(Geom;;Vector3d) || vec.is_a?(Array)
                e.parent.entities.add_line( e.start.position.offset(vec), e.end.position.offset(vec) )
              end # method
              end # proxy class
            end # plugin module
          end # Author's namespace
          I'm not here much anymore.
            Remmel
            i have the same problem... not to offset a edge... but offset a face in ruby code
            i hope TIG have a solution for this issue
            see example
            Set the house dimensions (in feet)
            @num_windows = 4
            door_width = 3
            door_height = 7
            house_height = 9
            house_length = (@num_windows + 1) * (door_width + 2) + 2
            house_width = 10
            roof_height = 2
            ents = model.entities
              pl = ents.add_face([0, 0, 0], [0, house_length, 0],
                 [house_width, house_length, 0],
                 [house_width, 0, 0], [0, 0, 0])
            	 pl.pushpull -1
            • TIGT Online
              First, your code...
              which I assume is just a sample...
              door_width = 3
              makes it 3" wide
              door_width = 3.feet
              makes it 3' wide !
              etc...
              I.E. force the use of a 'length', rather than passing a default 'number' - which SketchUp always interprets as inches !
              Also... you'd probably be better off adding a new group into model.active_entities and then adding your new geometry into that group.entities
              Currently your code draws a rectangle on the ground [Z=0 - and 0 is 0 in ALL length-units!] and then you extrudes it downwards by -1["]...
              If you wanted -1' then use -1.feet etc
              AND... you haven't actually explained 'how' you want to 'offset a face' !?
              Your code uses 0 for all of the Z values used in the rectangle's corner-points, but of course you could use any value for those Z's - but remember that they should be set to the same length if a valid 'flat' rectangle is to result...
                Remmel
                @tig said:
                First, your code...
                door_width = 3
                makes it 3" wide
                door_width = 3.feet
                makes it 3' wide !
                etc...
                now i know in Sketchup API , there is no method to offset a face.... but i thought to offset a face like this..... pl.offset 1, to get a border of 1" width
                • TIGT Online
                  You can replicate an offset for a face.
                  The code is not so simple.
                  Install my old tool https://sketchucation.com/pluginstore?pln=TIG_Smart_offset
                  Read the code and try to understand how it works...
                  It's somewhat more complicated than you need, but you should be able to extract what you need...
