    @Jim: Protrude plug-in for paneling
    7 Posts 4 Posters 692 Views 4 Watching
      rv1974
      Hi Jim!
      I've found the protude.rb could suit very well for 'paneling' the desired (pre-segmentified) surfaces. There's only one problem to solve: corners.
      The point is that there's no tapering at the wall corners.
      Here's some google-translated explanation:
      http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&eotf=1&u=http%3A%2F%2Fmaratshevchenko.ru%2Fblog%2Fall%2Fnavesnoy-fasad-iz-kompozitnyh-paneley-geometriya%2F
      So.. I'm trying to hint that 3 things should happen to turn the protude into a perfect paneling plug-in:
      1. it should process edges (rather than faces)
      2. the special attention shoud be paid to cornet treatment.
      3. tapering inwardthe wall.
        What do you think?
        BTW. for vrayers: the's a great panel material tutorial on the mentioned blog.
      • mitcorbM Offline
        mitcorb
        You use the word "tapering". Do you mean rounding/filleting, or beveling/ chamfering?
          rv1974
          the 2nd one: beveling/ chamfering- for lower poly count.
            Generate Ceiling Grid , Panelization by Sdmitch ?
              rv1974
              what about the corners?
                Stop the grid before the corner and apply special components ?
                Look at Component Dropper by Thomthom
                  Jim
                  Adding these features would likely require a complete re-write of the Protrude plugin, and that is not something I am planning on anytime soon. 😞
