    Print a plan or a 3d model in right scale
    7 Posts 2 Posters 454 Views 2 Watching
    • P Offline
      pier70
      Is there the possibility to print a plan view or a elevation in a right scale like 1:100 1:200; 1:50 etc, only in SU without layout use? than k u
        Sure there is but make sure you follow the steps (parallel projection, standard view etc) on this page:
        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114462
        and here is an explanatiion of the Print window (for Windows):
        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114459
        • P Offline
          pier70
          thank u Gai, I tried, I'm tring to print a plan in A4 sheet, the print is right in 1: 100 but the drawing is not in the centre of the A4, when I try to insert the right scale the Page size change, but it can stay into A4 sheet, why the page size change?...
          Barbara.pdf
          • P Offline
            pier70
            a scale print is possible only in SU pro or also in free license?
              Yes, it is possible, as I wrote above (certainly in LayOut it is easier as you can adjust where and how the scale drawing appears on the page).
              From your pdf it seems you tried to print the thing on a portrait sheet. What if you set your printer to landscape?
              • P Offline
                pier70
                I 'm not able to understand, this is a little apartment, if I print it in A4 sheet 29,7 cmx21 cm it stay in without problems but when I try to scale it the sheet dimension in the page size window change automatically but I don't know why if i selected 29,7x21,0
                  There are a lot of settings in that window and I cannot know what you missed. Did you keep the "Fit to page" or "Use model extents" boxes on for instance? (As far as I remember, they need to be turned off)
