    SketchUp Command Line Switches
    7 Posts 5 Posters 6.7k Views 5 Watching
      Jim
      From this topic, here's a few command-line options for SketchUp.
      $ Sketchup.exe [opts] [file.skp]
      Where [opts] are:
      -DisableRubyAPI -RubyStartup "/path/to/ruby.rb" -template "/path/to/template.skp" -notemplate -page "Scene1" -timing
      These may be options, but I haven't been able to verify they work:
      -DisableAutoSave -DisableWarnIfReadOnly -thumbnail -thumbprefs
        driven
        cheers Jim,
        on a mac, because of the ridiculous Google Folder you need to use, unless you add it to the ~.profile
        /Applications/Google\ SketchUp\ 8/Sketchup.app/Contents/MacOS/SketchUp -DisableRubyAPI
        anyway, that one works...
        EDIT: it seems to work [as in it starts SU], but when you actually click SU, it continues loading, including the Plugins...
        john
          Jim
          Oh, that one might use a / (slash) instead of a - (dash)
            Aerilius
            -lang ru
            where the language is exactly the name of the localization folder in the resources directory. For example create a new folder of your favorite dialect (pfl) and load it with %(#000000)[-lang pfl]. It seems that eastern asian languages need also a special SketchUp.exe binary.
              driven
              knew I'd seen it before, needs a boolean
              %(#BF4080)[cd /
              Applications/Google\ SketchUp\ 8/SketchUp.app/Contents/MacOS/SketchUp -DisableRubyAPI YES]
              john
                TBoy
                Is it possible to start Sketchup with different location for plugins folder. For example - a thumbdrive or "disk name/MyFavoritePluginsFolder" ?
                • TIGT Online
                  SketchUp always includes its own Tools folder [and the nested Ruby folders] and your user Plugins folder in it load-path [ $:]
                  You can include addition plugins folders in the load-path array, and any scripts in there will load as SketchUp starts.
                  Fredo wrote a clever extension to do this for you.
                  https://sketchucation.com/pluginstore?pln=000_AdditionalPluginFolders
                  Read its More Info... pages for usage etc...
                  • F Frankn referenced this topic on
