    Dialog Boxes Gone Nuts!
    11 Posts 3 Posters 470 Views 3 Watching
    • JoelM3DMJ Offline
      JoelM3DM
      My dialog boxes (Materials, Components, Scenes, and all the rest) are acting disobedient. They do not open where I put them anymore, but are all on top each other on one monitor. (I have a 2 mon system.) How do you get them to behave?
      Somewhere I read, "make sure you have NOT checked "center dialog box on display"" but I do not see that anywhere.
      || Joel Metzger 3D Modeling
      || story-shorts.net - Animation with SU
        Aerilius
        Try Window β†’ Preferences β†’ Workspace β†’ Reset workspace. Does that help?
        • JoelM3DMJ Offline
          JoelM3DM
          I tried that ... it didn't help.
          • JoelM3DMJ Offline
            JoelM3DM
            Doesn't anyone know about this problem??
            • Chris FullmerC Offline
              I've never heard of that center dialog box on display option. Maybe its a system option, but I don't think its part of SU.
              Try opening SU. Then open the dialog windows how you want them. Then close SU. Then open SU again and see if they held their place. It typically works fine for me and I'm on a 2 monitor system as well. So try that, if it does not wrok, report back here. We'll try something else.
              Chris
              All my Plugins I've written
              • JoelM3DMJ Offline
                JoelM3DM
                Thanks Chris! Since I posted, I successfully retrieved my dialog boxes. I did this by going in Display Properties and temporarily reversing my 2 monitors -- "there they are!" -- and moved them onto the other monitor. (I'm on Windows 7.)
                However I have another major problem. Since "upgrading" from XP to 7 (those quotes around upgrading have an angry complaint attached), my system will not run SU without molasses-slow response time.
                  Have you played with the graphics settings in SU? Try playing with the OpenGL settings in the preferences window. Those can slow down SU if they are set poorly for your video card.
                  • JoelM3DMJ Offline
                    JoelM3DM
                    Hardware acceleration is greyed out.
                    Max texture gives a warning - I haven't tried.
                    Fast feedback does not seem to make a difference whether it is checked or not.
                    Those are the only choices in Preferences>OpenGL.
                    • JoelM3DMJ Offline
                      JoelM3DM
                      Chris, do you always wear a bowler when you surf??
                        Aerilius
                        With no hardware acceleration, everything is computed on the CPU which explains the slowness.
                        After upgrading to Windows 7, did you download and install the (new) graphics driver for your graphics hardware? That's the usual (minimum) thing one needs to do to get Windows have hardware acceleration.
                        Then of course hardware acceleration could be disabled on system level (somewhere in the graphics driver settings in system control center).
                        • JoelM3DMJ Offline
                          JoelM3DM
                          I updated my graphics driver. SU is maybe a wee bit faster, but not easy.
                          No, let me change that. I rechecked Preferences and now I can choose Hardware Acceleration. I checked it and restarted SU. Yes!! Now it works great.
                          Thank you!
