    Removing unwanted interior faces from a mesh?
    6 Posts 3 Posters 458 Views 3 Watching
      tomot
      There are a few rubies that were written to remove interior faces.
      Wikii wrote one: remove_inner_faces.rb
      & Kyyu wrote one: Delete_Interior_Faces.rb
      both of these scripts no longer do what they were originally designed to do.
      I'm wondering if changes, to the revised Ruby API lately, may have been the cause?
      Is there another Ruby, which my Search may have missed, that still does this task?
      Please find attached a small file which needs all interior faces to be removed, other then manually πŸ˜„
      faces.skp
      my plugins
      tomot
      • TIGT Online
        My 'SolidSolver' ?
        Group each 'finger' and process, as grouping so many balls-ups in one thing will exponentially extend the processing time !
        You could also give such tools a fighting chance by using the hide/section-tool to temporary remove some 'sides' and then erasing a the more obvious internal partition-faces by hand...
        Thomthom's SolidInspector will show the [many] problems... there are dozens of coincident faces, as well as intersecting internal partition-faces etc...
        It'll be almost impossible to get it to 'fix' without some manual prep to help it...
        faces.skp
        • pbacotP Offline
          If we are talking manual methods. Some shapes, I have found, are easier to clear by smoothing, so that one can pick all outside faces easily, then delete the rest.
          I think that does it successfully for such shapes (a couple french fries had a more than one surface, even when smoothed.) Getting them all solid takes seconds.
            tomot
            @tig said:
            My 'SolidSolver' ?
            This is one thing I'm hoping Trimble is going to tackle one day, but I'm not holding my breath. The importance of new SketchUp icons takes precedence I guess? πŸ‘Ž
            my plugins
            tomot
              tomot
              The idea behind and efficient unwanted interior face removal is first required before any additional subdivision can take place, precisely to have the mesh look less french fry like πŸ˜„
              my plugins
              tomot
              • pbacotP Offline
                French fries work for Frank Gehry!
                http://i134.photobucket.com/albums/q108/djcummingsnet/DisneyHallOrgan.jpg
                I like your array better!
