    Question : Select edges depends on degrees
    3 Posts 2 Posters 192 Views 2 Watching
    • pingpinkP Offline
      pingpink
      Hi ,
      Is there a way to " select edges on surface which depends on specific degrees " ,eg. Vertical structure is 360 degrees except 0 degree and Horizontal structure is only 0 degree.
      After that , I can use the specific components to run along edges.
      • cottyC Offline
        cotty
        An image would help to understand your question...
        my SketchUp gallery
        • pingpinkP Offline
          pingpink
          Here is my piktogramm to determine the degrees of edges on selected surfaces.
          I would like to select only edges following to the condition of structure.
          Mullion is random degree except 180 degrees , and transom is only 180 degrees.
          Thank you kindly
          The Idea of degree
