    Layer order in layers menu changes when turned on or off
    3 Posts 2 Posters 260 Views 2 Watching
    • Z Offline
      zook247
      Suddenly out of the blue when I turn a layer on or off it jumps either to the top or bottom of the menu. This drives me crazy. How do I set this back to how it originally works so that the layer doesnt change order? Where is the toggle for this? Quick answer highly appreciated thanks
      • Chris FullmerC Offline
        You've changed the sort order from "Name" to "Visibility". Just above the list of layers, there is a little bar that shows "Name", "Visibility", and "Color". You need to click on "Name" to change it so that it sorts by layer name. I'm not sure if you need to click it once or twice. If it is sorting from Z to A (Z at the top) then click it again and it will change to A to Z. Good luck!
        Chris
        All my Plugins I've written
        • Z Offline
          zook247
          thanks, i knew it had to be something ridiculously simple like that, but it had me stumped.
