    Graphic drawing tablet
    15 Posts 11 Posters 8.3k Views 11 Watching
    • B
      bob-designer
      Is anyone using a graphic drawing tablet with Sketchup? Check out the tablets at
      http://www.monoprice.com, under computer accessories, desktop accesseries. I am looking at the $49.00 model.
      Thanks for your help, Bob
      • T
        Trogluddite
        Hi Bob,
        Take care to check the specifications well - especially the capabilities of the driver software to assign the pen controls as you would like them, and in particular, how it will emulate the middle mouse button and scroll wheel controls. If it cannot do those things well, it may frustrate your workflow, as you can end up having to switch tools to navigate and zoom.
        I tried SU with my (very old now) Wacom tablet, but gave up very quickly because navigation just wasn't ergonomic enough. More modern tablets may well be better in this respect, but I wouldn't have too high expectations of a model in that price range.
          Maybe some touch palette permit to zoom b 2 fingers
          can be useful while you use the pen graphic whith the other hand 😄
          (some tablets give some free bundle Program like artRage 3, photo element, Adobe Photoshop Elements 10, Corel Painter SketchPad,Autodesk Sketchbook Express 2010)
          • S
            sonder
            I've used the Wacom Intuous 3 for years. Absolutely love it. I just bought the new Intuous 5 touch and love it even more. They work really well with SU.
            • Bob JamesB
              Bob James
              I bought a Wacom Intuous and tried for several weeks to incorporate it into my workflow, but could not. 😞 My work is engineering-oriented.
              @Sonder: In what way or for what tasks do you use yours?
              • olisheaO
                olishea
                same here bob. I just couldn't improve speed from a mouse and keyboard unfortunately. I have a wacom bamboo and it hasn't seen light of day for 2 years. Would be good if you did LOTS of photoshop.
                oli
                • Bob JamesB
                  Bob James
                  Yes, I certainly agree with that, but I'm quite sure that my skills in PhotoShop will never reach a level where the tablet would help. I've watched some video demos showing a "master" using a tablet and PS and it was amazing.
                  Still, I'd like to be wrong about a tablet being useful for other SU tasks.
                  • olisheaO
                    olishea
                    I think tablet PC is the way forward. Being able to draw on the actual surface where your image is displayed, just like pen and paper.
                    Graphics tablet isn't intuitive for me....you are looking at a screen but drawing somewhere else. Kinda like rubbing your belly while patting your head.
                    I found this device below simply quite amazing. It tracks every single movement your pen takes (you can even save layers while you are drawing). This would be an architect's best friend!
                    WACOM Inkling. This would be great for boofredlay, I love his sketch book images.
                    http://cache.gawkerassets.com/assets/images/4/2011/08/inkling-with-sketchbook.jpg
                    Video from gadget show (look 3 minutes into the video)
                    http://gadgetshow.channel5.com/gadget-show/videos/gadget-test/episode-8-london-sketching-apps
                    oli
                    • ToboboT
                      Tobobo
                      I to have an Intuous 3 and I find it very easy to use. I have set the lower button as 'middle click' and the second button as right click. I combine the tablet with my keyboard, it has sped up my modelling no end. I find it helps with trying to lock onto the right snap point. I also find the precision of the table better than a mouse.
                      Toby
                      Philippians 4:13
                      • N
                        notareal
                        What about Yiynova tablet monitors or digitizer displays, anyone tried or seen one in use? http://www.yiynova.com/En/products.php?fid=1
                        Yiynova DP10HD sounds interesting http://www.amazon.com/Yiynova-DP10HD-Digitizer-Display-Windows/dp/B008EYA9EG/
                        • Bob JamesB
                          Bob James
                          How true.
                          @notareal
                          The link to http://www.yiynova.com does not work.
                          • mitcorbM
                            mitcorb
                            The link worked for me. Maybe you have a blocker on?
                            • N
                              notareal
                              How true.
                              @notareal
                              Maybe this will work better http://avyy.org/ or http://www.amazon.com/b?me=A12GIJLV896YB3&ie=UTF8&qid=1359317398
                              • J
                                jingkun
                                I use a pressure senstivity stylus in work and at home with SketchUp on a XP-Pen Artist 12 ( https://www.xp-pen.com/product/64.html ) Pen Display Tablet , I only got them last month but has been pretty easy to get the hang of.
                                The trick is using the pen on the tablet and then also using kb and touch pad with my right hand for tricky and complex situations. However the pen has two buttons built in and also 6 on screen buttons you can program per application. So it’s pretty easy to add in features such as delete, undo and other tools. I also have programmed gestures on the tablet (two finger swipe left for undo etc).
                                • W
                                  witcher1345
                                  I agree with you, Wacom graphics tablets are simply superb. I myself am a user of one and am very pleased. And when drawing illustrations, I use the service https://create.vista.com/colors/palettes/easter-color-palette/ to find the right color palettes, there are a huge number of them and are often useful. Enjoy.
