    Set alpha of a face without material
    7 Posts 2 Posters 413 Views 2 Watching
    • N Offline
      niccah
      When I draw a face, the material of this face is nil.
      But how can I set an alpha value without setting a material?
      Following situation:
      • one large face and something behind that face
      • by clicking on a "show / hide" button, this large face should get semi transparent, to see, what's behind
      • by clicking it again, the face should get the same color as before.
      I would like to avoid, to set at first a material, so set an alpha value. And reverse it again...
      Do you have an idea, how I can handle this problem?
      Thank you very much for your help!
        You can't. πŸ˜•
        A new face has a default front material and back material, and they are both a plain color.
        If you want to make a face transparent then you need to assign it a material that is itself transparent; OR place the face inside a group or component-instance that has a transparent material, and thereby it will appear in the container's material provided that it and the default material...
        Swapping the material on a button click is quite easy to do.
        Alternatively your button click could simply hide/show the face, or move the face onto an OFF layer temporarily.
        BUT to give a lone face transparency you need to use a material...
        Why are you so set against this obvious [and only practicable] solution?
        • N Offline
          niccah
          Thanks TIG for your help! No, I'm not completely against this solution. I just thought, if it is possible to set alpha without any material, it would be great. However, then I have to set a material πŸ˜„
          I don't like to hide this faces completely, because, I would like to compare this large face and the face behind that...
            So remember the omat=face.material
            Make a new translucent material [OR reuse it if it exists]
            mats=Sketchup.active_model.materials name='Tranz' unless nmat=mats[name] nmat=mats.add(name) nmat.color="White" nmat.alpha=0.5 end#unless face.material=nmat
            Then face is reset later...
            face.material=omat
            Adjust the color and alpha of 'nmat' as desired...
            • N Offline
              niccah
              Now, it works alomost perfectly... I'm able to show / hide the right faces. But I have problems to the save the original material (in case of TIGs idea: "omat").
              How I can save the material for ever - means, one should be able to reopen Sketchup and show the faces again...
              I tried it with "Entity.set_attribute" => but there, I can save just strings... do you have an idea, how I can save the material itself? Or can I save the ID of the material and to show the faces, call the material by its ID again?
              Thanks for your help!
                In your 'Tool' code make a class variable @facesmats=[], 'push' [face, material], then with the methods onCancel() or deactivate() reset the face with its material, thus:
                @facesmats.each{|a|a[0].material=a[1]}
                To always exit as you started ?
                OR use a model.start_operation('xxx') and then if there are no real changes in subsequent the code use model.abort_operation to undo all changes, including the material swap[s]...
                • N Offline
                  niccah
                  Oh, okay, this is a nice trick...
                  I think, I will get a lot of problems, when Sketchup crashes...
                  What do you think about this idea:
                  I will create for every face, which has a material != nil a new material => name: face.to_s
                  To show the faces again, I will remove the materials again...
