    Decorative border
    8 Posts 6 Posters 792 Views 6 Watching
      JamesPhilip
      I created this model to give as a border to the sunshade of a building. But a large number of pieces are required for the entire length of all the sunshades. This increases the memory requirements for sketchup and the computer froze several times. So I decided not to use it. But I may find use for it in the future for modeling a Chair or a table or other such furniture.
      • Bryan KB Offline
        Very cool design.
        • DanielD Offline
          Daniel
          Nice. Why not create a texture from an orthagonal view?
          My avatar is an anachronism.
            d12dozr
            @jamesphilip said:
            ... a large number of pieces are required for the entire length of all the sunshades. This increases the memory requirements for sketchup and the computer froze several times. So I decided not to use it...
            Have to ask..you did make it a component, right?
            http://goo.gl/f7ooYh
              JamesPhilip
              Yes. I did make it into a component. Also tried to make all pieces of a single floor into a nested component. Then I assigned them to a new layer and turned off that layer while not working on it. All that didn't help to reduce the memory usage.
                seabass84
                Time for a new computer πŸ˜„
                I have never had a slowdown due to memory in Sketchup on my Intel i7 Ivy Bridge overclocked at 4.7ghz, Nvidia GTX 670 4gb, 16gb RAM, 256gb SSD.
                • pbacotP Offline
                  what are your slow-downs due to, if not memory? Or how do you know a crash is memory based or..?
                    seabass84
                    Mine doesn't slow down ever, there was one time I tried to load 20 floors of fully furnished apartments into a high-rise and it froze for 5 minutes but the floors loaded and rendered after the freeze.
