    Exploding tool
    3 Posts 2 Posters 317 Views 2 Watching
    • yitzharY
      yitzhar
      im looking for explode tool, not plugin that work as a command on the ruby cons'.
      i chacked the plugins list but all of the are rubys. (less than 3kb)
      the purpse is to asign shortkey to the command, some how the build in explode tool
      couldnt find in the short keys list ... πŸ˜•
      look for us on facebook : creatioIL
      • Chris FullmerC
        You have to have an object selected that you can explode, then you will see it listed in the shortcut menu. So select a group, then go check the shortcuts again, it will be there.
        Good luck!
        Chris
        All my Plugins I've written
        • yitzharY
          yitzhar
          perfect ... you'r the champion.
          thank you
