    OK to print?
    8 Posts 3 Posters 1.0k Views 3 Watching
      SketchUpNoobie
      Would anyone with any experience in 3D printing be able to take a quick look at this model and let me know if it will be alright to print? I am planning on printing with Sculpteo and just wanted to make sure everything turns out all right.
      Are the letters on the top going to be a problem? If so, I can remove them. Everything else I believe is above the 1mm minimum wall thickness. I'm just not sure about the faces, "solidness", etc. The model was not designed with 3D printing in mind so I'm just not sure.
      I really have no experience with something like this so any help would be awesome! πŸ˜„
      P.S. I am printing with Sculpteo's keychain-maker tool which offers a free plastic model with the cost of shipping (6 USD). I am planning on using it as an example of 3D modeling in a speech. It doesn't need to hold up too well, but I hope it does.
      2x4 Lego at standard Duplo size.
      SketchUpNoobie: the complete noob in all things SketchUp.
      • cottyC Offline
        cotty
        Your model have to be solid (e.g. "solid group" in the entity info window) and is not. Try to use some tools to find or to solve the problems like
        • SolidSolver (TIG)
        • Solid inspector (thomthom)
        • Manifold (TIG)
        my SketchUp gallery
          d12dozr
          I'd remove the letters or place them somewhere else with more room and make them bigger. After you do that, use Outer Shell (Tools > Outer Shell) to join any solid components together into one single solid.
          http://goo.gl/f7ooYh
            SketchUpNoobie
            Thanks for the tips guys!
            How does this look?
            lego_duplo_for_print.skp
              d12dozr
              Looks good! That would work just fine. πŸ‘
              If you want, you could also deboss lettering from the side to make things more interesting, like the attachment. Just make sure each part of the letter is ~1mm thick and just as deep. (also scale up to perform the operation...you can see missing faces in this quick example)
              • cottyC Offline
                cotty
                I've thought that this function is a PRO feature and searched in the online help...
                English
                German
                After this, I searched it in SketchUp an it is there in both free versions!? πŸŽ‰
                my SketchUp gallery
                  d12dozr
                  Yep, its in the free version too. πŸ‘ It was introduced with the Solid Tools, the rest of which are PRO only, but Outer Shell is available to everybody.
                    SketchUpNoobie
                    Alright, cool! And I think I'll try some lettering on the side, too. Thanks for the suggestion.
                    😲 I also thought this was pro only! Awesome! πŸ˜„
