    Problem with maxwell render
    extensions
    2 Posts 2 Posters 620 Views 2 Watching
    • V
      Valainis
      Hello!
      I recently started working with google skechup (version 😎 and maxwell render (version 2.6), and I ran in to some problems with night scene rendering. Problem is that when I check rendered image with Maxwell fire all emitters are working perfect, but when i render image in maxwell render some of emitters arent working at all, but those who work are wery dark and rendered picture is almost black. All emitters are made from .ldt files (I have used .ies, but results are the same) P.S. I found this topic in forum [http://sketchucation.com/forums/viewtopic.php?f=80&t=43766&start=15](http://sketchucation.com/forums/viewtopic.php?f=80&t=43766&start=15) , but it didnt help.
      • jason_marantoJ
        jason_maranto
        Most likely this is an emitter/instancing issue -- disable "use instances" to check.
        Also, you should probably update to the newest version of Maxwell and see if that clears the issue up.
        Best,
        Jason.
