    [Plugin] VisTools v1.3.4
    67 Posts 13 Posters 110.3k Views 13 Watching
    • Dan RathbunD
      Dan Rathbun
      Description
      SketchUp VisTools provides a few useful tools to help you in working with layers and entities within your models. (VisTools was created by Dana Woodman to mimic the AutoCAD style of visibility control.)
      The tools are as follows:
      • Hide Selected Layers -- Hide all layers that are within your selection.
      • Isolate Selected Layers -- Show only layers that are within your selection.
      • Hide Selected Entities -- Hide all entities (lines/faces/groups/components) that that are within your selection.
      • Isolate Selected Entities -- Show all entities (lines/faces/groups/components) that are within your selection.
      • Freeze Selected Groups and Components -- Lock and hide all selected groups and components. In effect, this "freezes" the group/component so you can work on other things without affecting it.
      • Unfreeze All -- Unlock and show all groups and components that are frozen (e.g. if they are both hidden and locked).
      • Show All -- Show all layers and entities within your model. This will NOT unfreeze groups or components.
        The plugin will create a Toolbar with buttons for each tool. It will also create a right-click context menu called "VisTools" which will let you right click on a selection to perform the above actions. Finally, the plugin will add a menu item to the "Plugins" menu.
      You can map these tools to short cut keys to make it even faster to use.
      Just go to "Window > Preferences" and go to Shortcuts.
      I mapped mine in the following ways:
      "Isolate Selected Layers" mapped to Shift I.
      "Hide Selected Layers" mapped to Shift H.
      "Isolate Selected Entities" mapped to I.
      "Hide Selected Entities" mapped to H.
      "Freeze Selected Groups and Components" mapped to Shift F.
      "Unfreeze All" mapped to Alt/Option A.
      "Show All Layers and Entities" mapped to Shift A.
      You can of course map them to any keys you want!
      Seasons Greetings !
      Dana Woodman is very busy lately, and does not have time to maintain his well regarded 2 plugins.
      He released these under the MIT License, and welcomes community support in extending & fixing them, etc.
      To that end... here is the next version of VisTools (formerly known as Freeze Utils, FreezeTools or similar.)
      These updates have been pushed into a forked GitHub online repository at:
      [url]http:https://github.com/DanRathbun/sketchup-vistools[/url]
      ( post-release of v1.3.4 )
      Fixes:
      • Korean (ko) language support file by Joseph Kim ([url=http:http://sketchucation.com/forums/memberlist.php?mode=viewprofile&u=150905]josephkim626[/url])
      • The description in the Preferences panel will not be updated until next release.
      Attachment is ONLY the VisTools_ko.rb file, wrapped in an RBZ archive, so it can be used as an updater for any version 1.3.4 & below.
      Install from "Extensions" panel of "Preferences" dialog.
      You need to restart SketchUp to load the new strings.
      v1.3.4
      IMPORTANT!
      Delete file: " **Plugins/load_Vistools.rb**"
      Delete folder: " **Plugins/IntrepidBear**"
      THEN.. install the new RBZ:
      IntrepidBear_VisTools_v1.3.4.rbz
      Fixes:
      • Added Swedish language support file (still may not load.)
      • Added encoding "magic comment" first line to all script files.
      • Fixed nil error in "VisTools.rb", line 208, in isolate_layers(),
      (when not in editing context, active_path() returns nil.)
      • Fixed nil error in "VisTools.rb", line 309, in isolate_entities(),
      • Flattened plugin directory to "IntrepidBear_VisTools"
      • Renamed "load_Vistools.rb" -> "IntrepidBear_VisTools.rb"
      v1.3.3
      Added:
      • Chinese Simplified (zh-CN) language support by Xiao Long ([url=http:http://sketchucation.com/forums/memberlist.php?mode=viewprofile&u=45456]guanjin[/url])
      • Other Asian language support files (preliminary):
      • Chinese Traditional (zh-TW)
      • Japanese (ja)
      • Korean (ko)
      v1.3.2
      Fixes:
      • Correct @@lang assignment in language file rescue block.
      (This bug prevented the fallback English language hash from being defined for asian languages.)
      v1.3.1
      Fixes:
      • Updated the isolate_layers() rescue clause like the others.
      (This change was missed in the last revision.)
      • Define an array to set the ordinal position of commands, and use it to populate the menus and toolbar.
      (Ensures the commands are always in the same order.)
      v1.3.0
      Fixes:
      • Only trap StandardError subclasses in rescue clauses.
      Re-raise the exceptions (for a debugger or development tool.)
      • Isolate selected entities
      Do not isolate wrapping ancestors, if within an editing context.
      • Isolate selected layers
      Do not isolate ancestor's layers, if within an editing context.
      v1.2.1
      Fixes:
      • Revised language file load error notice.
      • Prevent unnecessary undo operations when nothing to be done.
      • Fixed: Undo operation names were not localized.
      • Fixed: unfreeze_all() and show_all() method descriptions.Added:
      • Added Dutch (nl) & Czech (cs) language support.
      • Gray-out commands that rely upon selection, when it is empty.
      • Add UI disable during undo operations for SketchUp versions 7+.
      v1.2.0
      Fixes:
      • Removed the use of instance references that were being set ONCE when SketchUp started.
      This prevented using the tools on any model opened later in the session, and on Mac would not work with multiple open models.* The plugin was defined in a class used in a singleton manner (which 99% of time means it should be a module instead.) The VisTools class was changed to a module, using a nested anonymous singleton proxy class instance.* many local vars changed to module vars* changed some "Google" references to "Trimble"* removed references to ExtendSketchup.com, as it is now shutdown (bummer)
      Not Added:
      I did NOT add any new functionality (nor change the way the tools currently work.)
      Added:
      • "Debug Mode" toggle added to the menu* Multi-Language support.
      • The plugin will look for "VisTools_XX.rb" files, in it's directory, where XX matches the first 2 characters of the language SketchUp is running in.* These rubies initialize @@menutext and @@tooltips hashes that contain string values.* If a file does not exist for the user's language, English is used.* These hash rubies must be wrapped in the plugin's namespaces, AND be saved as UTF-8 without BOM encoding.
      There is a sample "VisTools_en.rb" file that can be used as a template..
      *** The debug messages for this version are still in English**
      Appreciate testing to be sure the langauge hash rubies load correctly, and their strings are correct.
      Currently there are files for cs, de, es, fr, it, nl, pl, pt and ru
      v1.3.3: Added files for ja, ko, zh-CN & zh-TW
      Please give feedback on language support, and using with multiple models on Mac.
      THANK YOU to :
      • Xiao Long ([url=http:http://sketchucation.com/forums/memberlist.php?mode=viewprofile&u=45456]guanjin[/url])
      Chinese Simplified (zh-CN) language file.
      THANK YOU to :
      • [url=http:http://sketchucation.com/forums/memberlist.php?mode=viewprofile&u=12502]jolran[/url]
      Swedish (sv) language file.
      This file has been included with versions 1.3.4+
      Copy to ".../Plugins/IntrepidBear_VisTools/" directory
      Note: I do not think SketchUp will run in a Swedish mode, currently. Perhaps an update in the future to force using a non-standard language?
      The descriptions for the Extensions dialog are all literals in the "IntrepidBear_VisTools.rb" file (which also must be UTF-8 without BOM encoded.)
      Again, If you wish to send changes (or attach them to this thread,) be sure to save the file as "UTF-8 without BOM".
      Cheers.
      I'm not here much anymore.
      • simon le bonS
        simon le bon
        Hi Dan,
        Thank you to maintain these VISTools
        IntrepidBear_VisTools_1_2_0.rbz downloaded 👍 thanks.
        Here are some informations about these tools . (after I have searched by myself this morning)
        author site:
        https://github.com/danawoodman/sketchup-vistools/tree/master/IntrepidBear/VisTools
        SketchUcation:
        [Plugin] VisTools
        by ishboo » Fri Apr 08, 2011 12:03 am
        http://sketchucation.com/forums/viewtopic.php?f=323&t=36465
        @ishboo said:
        Hey Everyone,
        I've written a collection of SketchUp visibility utility functions that allow you to:
        • Hide selected entities (faces, edges, groups, components).
        • Hide selected layers.
        • Isolate (aka Show Only) selected entities.
        • Isolate selected layers.
        • Freeze selected groups and components (hide & lock).
        • Unhide all entities (does not unfreeze frozen items).
        • Unfreeze all groups/components (does not unhide all items).
        These tools work in concert to allow you to mimic an AutoCAD like workflow when working with items in your model.
        I've desired the ability to "Freeze" items in a model so I can work on other items without affecting them. This can be accomplished by using the Freeze tool to lock and hide items which allows you to modify and hide/show other entities without affecting the frozen items.
        Download:
        You can download the newest version of the plugin here: http://extendsketchup.com/plugins/dana/vistools/
        The code for the tool is released under an MIT license and hosted at GitHub:
        Report any bugs or issues here:
        https://github.com/danawoodman/sketchup-vistools/issues
        Update (9/27/12): I've changed the name of the plugin from the generic "Utilities" to "VisTools" to avoid confusion with other plugins. I've also updated the location of the Github repo and fixed a few bugs. It is now hosted on ExtendSketchUp.com as well.
        Please let me know what you think!
        Page 2:
        http://sketchucation.com/forums/viewtopic.php?f=323&t=36465&start=15#p350198
        @dan rathbun said:
        Version 2.x is coming .....
        Language translators, and proofreaders needed.
        I did the German (de) and Spanish (es) files, and they need proofing. (It's been 35 years since I took Spanish in high school, and I only 'dabble' in German when doing genealogy research.)
        The files need to be Unix line endings (EOL) and UTF-8 encoded. They are named "basic_utf8_XX.hash" and "debug_utf8_XX.hash", where XX is replaced by the lowercase language code. (ie: 'en', 'es', 'pl', 'fr', etc...)
        The plugin will "auto" find these files, or the user can choose a specific lang from those that are present. (In 'en' mode, the hash files are not actually loaded... as the Ruby code knows what the English strings are.)
        <----<<<< PM me if you'd like to do a certain Language translation, or proofread/correct the 'de' or 'es' files.
        If a debug hash file is not available for a certain language (but the UI strings in a basic hash file are present,) then the UI will be in that local language, and console output will be in English (if the user has turned it ON.)
        So... the priority is on the 'basic' hash files, in order to show the UI elements in the local language.
        replaceable parameters
        %s will be replaced by a number, like: 34
        '%s' will be replaced by an entity flag, like: '#<Sketchup::Face:0x624452c>'
        [attachment=0:3t29cmjw]<!-- ia0 -->words.txt<!-- ia0 -->[/attachment:3t29cmjw]
        NOTE! The above file, and the hash file in the next post, will be used with ver 2.x,... they do NOT work with ver 1.0 (if that's why y'all are downloading, but not volunteering to translate.)
        Translator links: Google Translate : MicroSoft Translator
        Last post p4
        http://sketchucation.com/forums/viewtopic.php?f=323&t=36465&start=45#p446921
        @dan rathbun said:
        [Plugin - Beta] VisTools v1.2.0 ready for testing
        We are then gone back to the first post of this present thread 😉
        ++ Simon
        • Dan RathbunD
          Dan Rathbun
          @simon le bon said:
          Page 2:
          Utilities](http://sketchucation.com/forums/viewtopic.php?f) (renamed VisTools)":27wl27ao]Version 2.x is coming .....
          ... We are then gone back to the first post of this present thread 😉
          Simon,
          I suppose you are asking the question "What happened to FreezeTools v2.0 ?"
          (1) FreezeTools must be thought of as an experimental code fork of the original, that was never released.
          (2) Some organizational ideas for the code were used by Dana in the VisTools v1.1 (or v1.0.1 ?) release.
          I am guessing that I had made the codebase for FreezeTools much too complex, in too many files. Again (guessing,) I think Dana did not have the time to test it, but needed to update the original, and decided to keep the update as simple as possible, still in one file, and include only the most important revisions, which were the name change to VisTools, and wrapping the code within his new IntrepidBear module namespace.
          And probably, that was the correct decision. (I think I got carried away, and broke the code up into far too many files. Also, I likely introduced too many changes all at once. It is better to do changes in smaller increments, for debugging, and just in case that "fork" must be rolled back if it does not work out.)
          But... since VisTools still needed an update to correct the multi-model situation on Mac, I said to myself,
          "Why waste the work I and others did creating the language strings for FreezeTools?"
          I still have all those language hash files, so I used the language strings, but in a slightly different way. (I no longer read the file as a hash literal into a string object, and then eval() it. I just let the interpreter use the language file via the load() method.)
          SO .... this really is where we should be.
          Version %(#000000)[1.2.0] is just a small incremental change that adds multi-model support, and loads localized language strings for the menus, toolbar, and tooltips.
          • Dan RathbunD
            Dan Rathbun
            Pushed v1.2.0 into a forked GitHub online repository at:
            • Dan RathbunD
              Dan Rathbun
              UPDATE: v1.2.1
              (see first post)
              • simon le bonS
                simon le bon
                Hi Dan,
                @dan rathbun said:
                Simon,
                I am too new with these tools to ask such a question: but it is an interesting reply 😉
                This have made me realize that I hadn't enough noticed that we where in the Developers' Forum
                Alas, I regret but coding matter is not my cup of thea 😐
                Anyway, Thank you in advance for the future developments..
                (I have some problems and things to understand with Vistools layers management but I go to [Plugin] VisToolsthread to discuss 😉 )
                *simon
                • jolranJ
                  jolran
                  "Look Mom! No code outside the author's namespaces." 😄
                  Looks like very tidy code. And well documented. Will study this.
                  • Dan RathbunD
                    Dan Rathbun
                    😛 Yup.. you're the first to notice my little quip.
                    But it is true. There is usually never a need to write normal plugin code, that evals outside your author namespace.
                    Yes it should serve well as good, simple plugin example.
                    • Dan RathbunD
                      Dan Rathbun
                      UPDATE v1.3.0 (see first post)
                      Pushed update into a forked GitHub online repository at:
                      Fedback via: https://github.com/DanRathbun/sketchup-vistools/issues
                      • simon le bonS
                        simon le bon
                        Hi Dan,
                        You surf on the lip of the wave.
                        After a little while of use; once we have begun to integrate its functionalities in our workflow, this tool appears as natural as a basic one !
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/IntrepidBear_VisTools_1_3_0_01.jpg
                        v1.3.0 Downloaded,
                        Thank you ++
                        simon
                        • Dan RathbunD
                          Dan Rathbun
                          @simon: Are the français menu text and tooltips working correctly for you?
                          • simon le bonS
                            simon le bon
                            Everything looks perfect in the two areas 👍 😉
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/IntrepidBear_VisTools_1_3_0_001.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/IntrepidBear_VisTools_1_3_0_002.jpg
                            A suggestion:
                            May be a red icon or light to signal something is hidden or frozen as a reminder would be useful. I think that with a complex model stratified on numbered layers, things can be loosen into the hidden world easily.
                            simon
                            • Dan RathbunD
                              Dan Rathbun
                              Thank you for the feedback Simon!
                              • Dan RathbunD
                                Dan Rathbun
                                Issue #19: Toolbar button ordinal positions
                                In the old pre v1.2.x versions, the plugin commands were added to the VisTools toolbar in a hard-coded manner.
                                In my versions (v1.2.0 to v1.3.0,) I first loaded all the commands into a Hash, and then later iterate this @@command hash adding the commands to both the toolbar and menu.
                                The problem is that in Ruby v1.8.x, the order of keys returned when using an each iterator, is not ALWAYS the same order in which they were added to the hash.
                                Anyone notice the position of toolbar buttons changing from one session to the next ??
                                I may need to modify the code to be sure the buttons are always in the correct order.
                                ADD: Issue filed for milestone 1.3.1, and fix has been done.
                                • Dan RathbunD
                                  Dan Rathbun
                                  ➡ UPDATE v1.3.1
                                  Feedback via: https://github.com/DanRathbun/sketchup-vistools/issues
                                  • guanjinG
                                    guanjin
                                    @dan rathbun said:
                                    ➡ UPDATE v1.3.1
                                    Aviso para cargar error
                                    I come from China, is to learn
                                    • Dan RathbunD
                                      Dan Rathbun
                                      @__guanjin__:
                                      The plugin should have just used English ...
                                      ... because I did NOT supply language files for zh-CN (Chinese Traditional), zh-TW (Chinese Taiwanese), ja (Japanese) or ko (Korean.)
                                      %(#BF4000)[I do not know how to create UTF-8 encoded language files for these languages.
                                      (I think they may use UTF-16 encoded characters.)]
                                      Questions:
                                      Are you running SketchUp in chinese ? zh-CN or zh-TW ??
                                      At the Ruby Console, what is the result of:
                                      Sketchup.get_locale
                                      and:
                                      Sketchup.get_locale()[0,2]
                                      • A
                                        Anton_S
                                        Hey Dan, the script and organization is amazingly profesional. 😮 Indeed, I need to upergrade my scripting skills now...
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Thank you Anton
                                          • A
                                            Anton_S
                                            I examined the Vis Tools.rb and find it strictly licened. What bugs me is the whole licence thing: ❓
                                            1. How do I get it? I found a link here, though I'm still not sure.
                                            2. What kind of licence should I get? MIT?
                                            3. Is it required to pay for the licence?
                                            Sorry if my post is a bit of topic though 😳
                                            • 1 / 4
