    [Plugin] VisTools v1.3.4
    67 Posts 13 Posters 108.4k Views 13 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Pushed v1.2.0 into a forked GitHub online repository at:
      https://github.com/DanRathbun/sketchup-vistools
      I'm not here much anymore.
        Dan Rathbun
        UPDATE: v1.2.1
        (see first post)
        • simon le bonS Offline
          simon le bon
          Hi Dan,
          @dan rathbun said:
          Simon,
          I suppose you are asking the question "What happened to FreezeTools v2.0 ?"
          I am too new with these tools to ask such a question: but it is an interesting reply 😉
          This have made me realize that I hadn't enough noticed that we where in the Developers' Forum
          Alas, I regret but coding matter is not my cup of thea 😐
          Anyway, Thank you in advance for the future developments..
          (I have some problems and things to understand with Vistools layers management but I go to [Plugin] VisToolsthread to discuss 😉 )
          *simon
          • jolranJ Offline
            jolran
            "Look Mom! No code outside the author's namespaces." 😄
            Looks like very tidy code. And well documented. Will study this.
              Dan Rathbun
              😛 Yup.. you're the first to notice my little quip.
              But it is true. There is usually never a need to write normal plugin code, that evals outside your author namespace.
              Yes it should serve well as good, simple plugin example.
                Dan Rathbun
                UPDATE v1.3.0 (see first post)
                Pushed update into a forked GitHub online repository at:
                Fedback via: https://github.com/DanRathbun/sketchup-vistools/issues
                  simon le bon
                  Hi Dan,
                  You surf on the lip of the wave.
                  After a little while of use; once we have begun to integrate its functionalities in our workflow, this tool appears as natural as a basic one !
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/IntrepidBear_VisTools_1_3_0_01.jpg
                  v1.3.0 Downloaded,
                  Thank you ++
                  simon
                    Dan Rathbun
                    @simon: Are the français menu text and tooltips working correctly for you?
                      simon le bon
                      Everything looks perfect in the two areas 👍 😉
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/IntrepidBear_VisTools_1_3_0_001.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/IntrepidBear_VisTools_1_3_0_002.jpg
                      A suggestion:
                      May be a red icon or light to signal something is hidden or frozen as a reminder would be useful. I think that with a complex model stratified on numbered layers, things can be loosen into the hidden world easily.
                      simon
                        Dan Rathbun
                        Thank you for the feedback Simon!
                          Dan Rathbun
                          Issue #19: Toolbar button ordinal positions
                          In the old pre v1.2.x versions, the plugin commands were added to the VisTools toolbar in a hard-coded manner.
                          In my versions (v1.2.0 to v1.3.0,) I first loaded all the commands into a Hash, and then later iterate this @@command hash adding the commands to both the toolbar and menu.
                          The problem is that in Ruby v1.8.x, the order of keys returned when using an each iterator, is not ALWAYS the same order in which they were added to the hash.
                          Anyone notice the position of toolbar buttons changing from one session to the next ??
                          I may need to modify the code to be sure the buttons are always in the correct order.
                          ADD: Issue filed for milestone 1.3.1, and fix has been done.
                            Dan Rathbun
                            ➡ UPDATE v1.3.1
                            Feedback via: https://github.com/DanRathbun/sketchup-vistools/issues
                            • guanjinG Offline
                              guanjin
                              @dan rathbun said:
                              ➡ UPDATE v1.3.1
                              Aviso para cargar error
                                Dan Rathbun
                                @__guanjin__:
                                The plugin should have just used English ...
                                ... because I did NOT supply language files for zh-CN (Chinese Traditional), zh-TW (Chinese Taiwanese), ja (Japanese) or ko (Korean.)
                                %(#BF4000)[I do not know how to create UTF-8 encoded language files for these languages.
                                (I think they may use UTF-16 encoded characters.)]
                                Questions:
                                Are you running SketchUp in chinese ? zh-CN or zh-TW ??
                                At the Ruby Console, what is the result of:
                                Sketchup.get_locale
                                and:
                                Sketchup.get_locale()[0,2]
                                  Anton_S
                                  Hey Dan, the script and organization is amazingly profesional. 😮 Indeed, I need to upergrade my scripting skills now...
                                    Dan Rathbun
                                    Thank you Anton
                                      Anton_S
                                      I examined the Vis Tools.rb and find it strictly licened. What bugs me is the whole licence thing: ❓
                                      1. How do I get it? I found a link here, though I'm still not sure.
                                      2. What kind of licence should I get? MIT?
                                      3. Is it required to pay for the licence?
                                      Sorry if my post is a bit of topic though 😳
                                        Dan Rathbun
                                        😆 The MIT License is very NON-Strict.
                                        Really there are only 2 requirements: that the copyright notices of the previous authors must stay in the code documentation (you add your own name if you make changes and distribute an edition of your own;) and the original License text (and it's requirements, along with it's 2 restrictions, AND ALL it's privileges,) must be passed on to any future users, or authors.
                                        Basically.. the "MIT License" is a liberal, socialistic, community property type of license, that is meant to encourage "open source" projects that anyone can use, and improve. Since many people may put their valuable time into the product and do not want some entity "stealing" their work and turning it into a commercial product,... the license has the requirements that the contributor copyright notices and all privileges to use or modify the software, must be passed on.
                                        @anton_s said:
                                        How do I get it?
                                        The license text IS distributed with the plugin in " %(#004080)[**LICENCE.txt**]", ...
                                        and I also pasted it into the documentation headers of the " %(#004080)[Plugins/load_VisTools.rb]" extension loader and the " %(#004080)[Plugins/IntrepidBear/VisTools/VisTools.rb]" main script file.
                                        IF you installed the rbz archive, then you have the license files.
                                        That website has nothing to do with THIS VisTools SketchUp plugin nor it's license.
                                        That website is a form guide that helps you decide what license to use with YOUR OWN projects, that have never before been subject to any "End-User License Agreement" (EULA), "Terms of Service" (TOS) or "Terms of Use".)
                                        The license attached to the plugin IS the MIT license.
                                        The terms of the MIT license (as distributed with the plugin,) along with the Warranty Disclaimer / Limitations on Liabilities, apply to your use of the software as it is now; and grant you privileges (subject to those 2 restrictions,) to modify or extend the software, and distribute your own edition.
                                        No ... but I would not mind donations to help pay for my time, or new features.
                                        I could have charged a fee for the updates (under the terms of the MIT license,) but chose not to, because I really did not add any new features. I just cleaned up the code mostly, and fixed a few things. The language support files were done by volunteers back when I forked off the edition that was temporarily called "FreezeTools".
                                        I do not use the VisTools plugin much myself, because I really do not feel it Freezes things the way they are frozen in AutoCAD. But I suppose it is better than nothing.
                                        Unless I get feedback from users who really like to use the plugin, and likely get some donations to do more work on it,... I probably will not do much more to it, other than fix any glaring bugs, that are easily fixed.
                                          Anton_S
                                          Thank Dan, that explains it well.
                                            Dan Rathbun
                                            @dan rathbun said:
                                            @__guanjin__:
                                            OK I found the error.
                                            It was me:
                                            VisTools.rb: line 95
                                            @@lang == 'en' %(#008000)[# just use English]
                                            should be making an assignment:
                                            @@lang **=** 'en' %(#008000)[# just use English]
                                            😳 'tupid booboo!
                                            I'll make changes and push an update.
                                            • 1 / 4
