    Scale
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    8 Posts 3 Posters 9.1k Views 3 Watching
    • micioneM
      micione
      I updated to the latest version (in Italian).
      When changing scale, the imported drawing disappears.
      Scale are all selected.
      Does anyone have this problem?
      • C
        Charlie__V
        micione,
        Same here.......oddly the 1"=400'type seem to work.
        However none of the fractional scales work.......total whiteout of the viewport.
        Charlie
        • micioneM
          micione
          This happens on Windows 7.
          But on "VISTA" seems to work well.
          I reported the bug to the service center.
          Let's hope so ...
          I wonder if we can re-install overwriting the previous version,
          without having to have problems with the plugins installed.
          Some help?
          • micioneM
            micione
            This is a solution:
            Delete all the default scale.
            Rewrite custom ones.
            Now it should work.
            • C
              Charlie__V
              All,
              FYI:
              Seems Trimble issued a repair for this today (I assume this was all that was fixed).
              I had an automatic notification on opening LO.....if you did not maybe try checking for update(About LO...check for updates)
              EDIT: Thank you Trimblers for the quick fix. πŸ‘
              Charlie
              • micioneM
                micione
                This is good news.
                I'm happy for you.
                When I reported the problem to technical support, they said
                that they had no other similar reports, and then try to reinstall SketchUp.
                Seem to have changed their minds.
                However, at least in the Italian version, we do not see any updates. For now.
                Hope is always the last to die.
                • K
                  karimtabbara
                  I have found the solution to this bug and reported it to sketchup team
                  Please see my topic below
                  https://productforums.google.com/d/msg/sketchup/Yi_b0m1_fh8/xW9nzXRf-TgJ
                  Solved the problem to many
                  Please report to sketchup team if it works for you
                  Ragards
                  • micioneM
                    micione
                    Thanks for the suggestion.
                    The problem appears on my desktop computer (windows 7).
                    I wonder why on my laptop (windows vista) the problem does not appear.
                    greetings
