    Plugin to toggle Expert Dimensions?
    5 Posts 4 Posters 475 Views 4 Watching
    • svzephyrS Offline
      svzephyr
      Is it possible to create a toolbar item which would quickly toggle Expert Dimensions on/off?
      I use Sketchup to frame walls for the houses Habitat builds here in Louisville, KY. I create a separate scene for each section of wall, and use dimensions a lot. I like to work with Expert Dimensions on so that I can identify and fix "busted" dimensions. However, before printing I turn Expert Dimensions off; some of my dimensions are actually notes and I don't want them to print the bright green "busted" color.
      I use Sketchup 70 Free, Windows XP.
      I'm an avid user of the great plugins available - some I've been using for so long I forget what's Sketchup and what's a plugin!
      Thank you for any help possible. Lynn
        Jim
        No, there is no way to control the expert settings from a plugin.
        • svzephyrS Offline
          svzephyr
          Thanks, Jim. I had looked through the API and couldn't find anything, but I was hoping I had just overlooked something. Lynn
          • cottyC Offline
            cotty
            I don't know Expert Dimensions, but perhaps you can add a layer for all dimensions to control their visibility?
            my SketchUp gallery
              blajnov
              You can create a layer of size and use it to enable or disable their visibility...
