    Interesting Shape -How would you go about this shape?
    Scheduled Pinned Locked Moved Organic Modelling
    13 Posts 4 Posters 10.4k Views 4 Watching
    • pjbazelP Offline
      pjbazel
      Some times I find a shape that bends my mind a little. I find I am never more obsessive with SU than when I have a particular shape in mind and haven't achieved, or perfected it yet.
      Just curious how you would go about creating this very unique futurist shape... Its the top I'm interested in. The continuous edge from the arc out and along the rail, also the perfect dome that meets the lower half in apparent symmetry, even though the back side must lose this symmetry.
      I have experimented with this shape, and obtained decent results, but not that perfect transition and dome that would really do it justice.
      There are a number of interesting things about this shape, give it a try and you'll see.
      Just been playing with this so long that I was curious if anyone else would find it interesting, or want to give it a crack. I figured organic modeling might be the right place for this, hope its not to far off.
      • panixiaP Offline
        panixia
        have you got a reference image for the backside?
        • pjbazelP Offline
          pjbazel
          Unfortunately, I don't.
          But I find its the continuous sweeping line from the opening in the dome that goes out along the edge of the balcony (if you can call it that) which is the most interesting feature. It is curious how the architect pictured the back joining given that the dome and base meet along the left edge.
          Glad to see I caught at least one persons imagination. 😍
          • pbacotP Offline
            I thought the basic shape was a flattened sphere cut by two smaller flattened spheres, then the center part is cut and curled back. As I look at the enclosure at the center in the picture, I can't figure out what's happening at the other side. It looks Escheresque.
            • panixiaP Offline
              panixia
              ahaha true πŸ˜›
              • pjbazelP Offline
                pjbazel
                I know its tricky, Lots of ways to go about it but none that quite respect the image.
                pbacot, nice organic approach, SS?
                I went with a more brute force approach. Its close but still not quite there.
                Quite a tricky little designee
                • panixiaP Offline
                  panixia
                  mmm.. the big glass surface should be curved on xy too.. you did it straight.. ❗
                  • TaffGochT Offline
                    TaffGoch
                    pjbazel,
                    That's a house sketch by Jacque Fresco, from Venus, Florida. He's a futurist-style architect, with grand civilization concepts (sort of like Bucky Fuller was.)
                    I played around with the design, to create in SketchUp, something akin to this house sketch.
                    I started with a sphere, and stretched it, with multiple portion scalings, to produce a shape similar to an almond.
                    From there, I used intersections of elliptical cylinder sections, to create portions of the almond to "cut-away." I performed similar intersections with the inner "more-spherical" group.
                    I didn't get an exact reproduction, on this first attempt, but the exercise does demonstrate that 3D modelling should be manageable, using such methods.
                    -Taff
                    ![I cut a "window" in the "almond," to show sphere section (group) inside](/uploads/imported_attachments/7EWm_Fresco1.png "I cut a "window" in the "almond," to show sphere section (group) inside")
                    ![Outer "almond" intersected with elliptical cylinder sections](/uploads/imported_attachments/STky_Fresco2.png "Outer "almond" intersected with elliptical cylinder sections")
                    Rotation & scaling, in preparation for inside sphere intersect operation
                    ![Exploded inner group, to merge with "almond," and cleanup of extraneous entities](/uploads/imported_attachments/3i2N_Fresco4.png "Exploded inner group, to merge with "almond," and cleanup of extraneous entities")
                    "Information is not knowledge." -- Albert Einstein
                    • TaffGochT Offline
                      TaffGoch
                      By the way, Fresco seems to like ellipsoid & "almond" shaped buildings, boats & aircraft for his designs.
                      Do a "Jacque Fresco" Google Image Search for plenty more examples.
                      (The second image reminds me of a roach -- the bug kind, not marijuana.) πŸ˜†
                      • pbacotP Offline
                        Excellent interpretation, of course, Taff! I realized later there was a sphere somehow off-center in the shape. I guess you have to scale parts of the almond leaving the intersection with the sphere untouched?
                        • TaffGochT Offline
                          TaffGoch
                          Yep,
                          Keep a vigilent eye, to make sure the edges shared by the 1/4-sphere and the 3/4-almond are not compromised, during scaling operations. Then the two groups will merge smoothly, when exploded.
                          BTW, I can see how pjbazel's interpretation, of the backside, may be correct. It may, indeed, be asymmetrical, unlike the "roach" house design.
                          -Taff
                          • pbacotP Offline
                            I got the bug to play with this some more.
                            I wanted to use an elliptical and sperical shape both squashed. I don't know how to exactly draw an elliptical sphere, but I did both with follow me. I used distorted spherical and cylindrical shapes to cut out parts using solid tools. I ended up having to use Artisan to subdivide the shapes some more because the boolean cuts were coming out jagged. I used joint push pull to add thickness.
                            My ellipse shape is too long-- so they have more patio space. and the rest is still not like the original shape. Came away impressed by Fresco's imagination with organic shapes, and his drafting and modeling genius. I see now how the original drawing's deck appears to rise at the back. It's a natural illusion.
                            • pjbazelP Offline
                              pjbazel
                              Nice!!
                              I took my eyes of this thread, didn't think it would see anymore action, but then I come back and wow! Nicely done guys!
                              Taff: Yes, Fresco, that's where I got the image! I took a screen capture from something I saw on youtube and then forgot where it came from. He's far out! lots of inspiration for modeling. Its funny to think that he uses those little plastic models to communicate his ideas rather than 3d models and renders. They look so dinky, hehe.
                              Great techniqe Stretching half of the sphere to get the almond shape, while melding with the proper sphere great idea. Ill have to play with that one and try to duplicate it.
                              also, leave it to the guy with the spinning geodesic as his avatar to make a weed joke...hahahah classic!
                              **pbacot:**nice refining of the techniqe, thats the closest yet, and who wouldnt want a little extra porche!
                              Thanks for playing along guys.......I knew there was somthing interesting about this shape, glad to see it gave you a bit of a bug too.
