    [REQ] copy along path fixed interval
    8 Posts 3 Posters 816 Views 3 Watching
    • P
      pibuz
      Hi all!
      Sorry to bother again: I am looking for a suggestion.
      I'm now modeling a complex road situation, with straight lanes and curved ramps. I have the basic road modeled now, with the border lines defining the asphalt surfaces. I have to add the protection barriers now, but it is a very long job doing it manually because the road section I have to model is huge.
      I've done a deep search through the plugins which could help me out and I found:
      1. copy along path
      2. component stringer
      Sadly, seems like I can't get the wanted result with neither of those.
      "copy along path" keeps my barrier component vertical, while I want it to be rotated to follow the ramp profile
      "component stringer" places a new component (perfectly aligned to the ramp profile) in every node of the line, when instead I need a component after the previous is finished.
      Basically, I'd need the correct orientation granted by the "component stringer" rb AND the spacing option of the "copy along path" plugin...
      Is there a way I can solve this?
      THANK YOU ALL A LOT IN ADVANCE!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • cottyC
        cotty
        Can Polyline divider (BezierSpline) in combination with component stringer help in this case?
        (Edit: changed picture)
        my SketchUp gallery
        • P
          pibuz
          YES! THAT DOES IT!
          Wonderful! Didn't know of the spacing tool from the bezier toolbar!
          Now I only have to re-draw all the polylines over the standard curves, but that is an easy and fast approximation. THANKS A LOT MATE!
          • cottyC
            cotty
            I think you can convert them directly...
            my SketchUp gallery
            • P
              pibuz
              Tried to, but seems that I can't..
              BTW, no problem my friend: the new workflow is much simpler and faster! 😎
              Thanks to you
              • guanjinG
                guanjin
                Is this it?
                I come from China, is to learn
                • P
                  pibuz
                  Hi Guanjin!
                  ..yeah, could be... but..what plugin is that?
                  • guanjinG
                    guanjin
                    @pibuz said:
                    Hi Guanjin!
                    http://sketchucation.com/forums/viewtopic.php?t=14770
                    Here
