    Solid works conversion
    3 Posts 3 Posters 281 Views 3 Watching
      deanlegg
      Hi All
      I need to convert a file in solid works to SU
      I think the file is ERMS (whatever that is)
      Will it convert, and which format would you convert it to ?
      Thanks Dean
        d12dozr
        You should be able to save as DWG/DXF and import that into Sketchup.
        http://goo.gl/f7ooYh
        • sketch3d.deS Offline
          sketch3d.de
          if the DXF/DWG does not work for you or if you do not have access to the DWG-Editor of SWX, you can also export from SWX to STL and import the STL file in SU by installing the STL f. SU plugin.
          hth,
          Norbert
