    [Style] Straight 2B Pencil Style
    6 Posts 3 Posters 1.8k Views 3 Watching
      Another pencil line style I'll be releasing shortly.
      The shadows are run through Fotosketcher.
      I think it is cool that you can change the look of a line style simply by changing the export size. Look at them at full size for comparison.
      Exports at 2K px wide
      Lines exported at 3K px wide
      • Mike LuceyM
        Mike Lucey
        Like that effect a lot πŸ‘
          Thanks Mike.
          I've added that one along with a similar but less straight style here. Here's an example of that second style with the same shadows as above.
            Both styles are now available in a single download here. They're free for Premium members.
            • pbacotP
              Dave,
              Thanks. These are good ones. One needs to click up the full size image to appreciate. I guess the hardness of pencil depends on the output resolution.
                Thank you, Peter.
                The output size (and the viewing size) does indeed affect the appearance of the lines. The larger the output size, the thinner and in this case harder the lines appear.
                Here's an example. I used the same line style, the Straight 2B Pencil from above, and made a series of exports at different sizes. The smallest was 800 pixels wide which shows on the left. I then resized the larger images so they are all the same size. As you can see, by changing the export size you can vary the appearance of a single line style quite dramatically.
                I often export lines at a larger size than the rest of the model so I can make the lines very thin. This also allows me to manipulate the image/textures and so on without affecting the lines.
