    How to make a frame/dialog/window always on top?
    23 Posts 7 Posters 4.8k Views 7 Watching
    • A
      alexmojaki
      I want a small frame/dialog/window (showing a color gradient scale) to show in a corner in front of the model. I can't use a Web Dialog because it disappears to the background when I click on the model outside the dialog, and I can't use show_modal because in Windows that would mean (as far as I understand) that no interaction with the model is possible until the dialog is closed.
      I considered wxSU, but then when I tried installing it it didn't work for a while. I realised the problem was that the plugin files had been mysteriously placed inside the newly created folder 'Google Sketchup 7' instead of 8. This is on a Mac.
      This is for a commercial plugin, and I need it to be user friendly. I do not want to have to have installation instructions that say 'download and install wxSU, then maybe move some files from one folder to another.'
      Any suggestions please?
      • A
        Aerilius
        "Always above" is an (optional) window manager feature, on Windows and probably OS X it's mainly exposed to developers but not end users.
        It's correct what you found that SketchUp's webdialogs are bugged: in the OS X version, webdialog.show_modal() is not modal at all, but it's always on top (what show() should be). It hasn't been fixed yet, so we commonly just use a simple conditional:
        if OSX
        else # (elsif WIN)
          webdialog.show()
        using boolean constants (in your namespace) for the operating systems, as described in FAQ: Detect if plugin is running in the OSX vs Windows version of SketchUp ?
        • A
          alexmojaki
          So are you saying that in Windows, show() keeps the dialog always on top? I wasn't expecting that, since it certainly doesn't in Mac, and the API didn't seem to suggest that. Or the name of the function. Or just common sense. I thought that it shows it but then it can be hidden again when it goes out of focus.
          • Dan RathbunD
            Dan Rathbun
            YES ... because on MS Windows child window objects have a Z order higher than the owner window object. (UI speaking, everything on the screen, is a child window object. This includes menus, editboxes, buttons, ... all controls, .. everything is a window object; or some subclass of the base window class.)
            @alexmojaki said:
            I wasn't expecting that, since it certainly doesn't in Mac, ...
            The concept of what "modal" means differs between the Mac and Win development world.
            @alexmojaki said:
            ... and the API didn't seem to suggest that.
            The API dictionary is long overdue for an overhaul !
            Get ThomThom's WebDialogs - The Lost Manual β€” R1 09 November 2009 in PDF
            ... or read a condensed edition in forum topic:
            Yea... the previous example method could be wrapped in a cross-platform method named:
            .show_atop()
            (I think I'll enter an API Request for it.)
            It is frustrating to have methods with the same name, that have differing behavior on Mac vs Windows !! Your not the first to complain ... and likely not the last.
            Sometimes things get "out of whack" on Windows.. and we need to call the bring_to_front() method, but it's rare. That method is of more use on the Mac.
            We can actually also force a hidden child window on MS Windows, but it requires making system calls the change the Z-order of the child window to less than that of the owner window, or hide it in some way.
            But that's a pain-in-the-butt, and not necessary anyway, because the UI::WebDialog class has a means to hide the window, via the close() method.
            This does not destroy the UI::WebDialog instance! It can be opened again later by calling either one of the show methods. However, the HTML will be re-loaded, so in order to restore any information or control selections, it is up to YOU to save them on the Ruby side into instance variables, before the dialog closes.
            Likewise, it is YOUR responsibility to restore any dialog information and control selections after the dialog opens / re-opens. πŸ€“
            I'm not here much anymore.
            • A
              alexmojaki
              Awesome, thanks a lot to both of you!
              • A
                alexmojaki
                OK, it's not working as I had hoped.
                What I wanted was for the dialog to show when a particular object was selected. It does, but then I want the user to be able ton continue to interact with the model, e.g. orbit the camera, while the scale is still showing, just out of focus. But when the object is selected, and the dialog appears, it of course starts out by being in focus. While I'd like this to not happen, it's acceptable. But when I click on the same object again, onSelectionBulkChange gets called again, even though nothing has changed, and so before it would 'reshow' the dialog, thus keeping it in focus no matter what, and making it impossible to use Sketchup. I tried inserting a conditional to avoid this so that the dialog is only shown when the selection is genuinely changed, but now when I re-click the same selection to try and bring Sketchup into focus, the dialog disappears completely. It's not even in the background, and it's certainly not on top as I thought show_modal would make it. I know from the puts statements that the conditionals are working as expected: only 'b' is output, so the dialog isn't being closed. It's just not staying on top.
                class ScaleSelectionObserver < Sketchup;;SelectionObserver
                	def initialize()
                		@dialog = UI;;WebDialog.new("Color scale", false, "Color scale", 70,160,5,100, true)
                		path = Sketchup.find_support_file("scale.html",#...#)
                		@dialog.set_file(path)
                		@prevSelection = nil
                	def onSelectionBulkChange(sel)
                		if #the selection is appropriate# and sel.length>0
                			puts 'b'
                			if not sel.to_a==@prevSelection
                				puts 'a'
                				@dialog.show_modal
                				@prevSelection = sel.to_a
                		else
                			puts 'hi'
                			@dialog.close
                	def onSelectionCleared(sel)
                	    @dialog.close
                # Attach the observer.
                Sketchup.active_model.selection.add_observer(ScaleSelectionObserver.new)
                • Dan RathbunD
                  Dan Rathbun
                  Being able to change the focus from a dialog or toolwindow, back to the main SketchUp window, (and visa-versa) is a current problem we have discussed before.
                  We have entered API request for this.
                  • A
                    alexmojaki
                    Sigh. OK, thanks. You should probably also note that neither show nor show_modal keeps the window on top in Mac. I've even checked with another case.
                    • thomthomT
                      show_modal will keep the WebDialog on top of the SketchUp window under OSX. But not on top of all other child windows of SketchUp.
                      • TIGT
                        Your test
                        Presumably you have some 'real code' in there... otherwise the line is
                        if
                        as everything after the first # is ignored ?
                        Then you'll always get 'b'...
                        Also [incidentally] the
                        would be better as
                        path = File.join(File.dirname(__FILE__), "scale.html")
                        assuming it's in the same folder as the ruby script itself...
                        • A
                          alexmojaki
                          So, returning to my original question, since WebDialogs won't work, how do you suggest that I make the scale always show on top? Is wxSU my only option?
                          • Chris FullmerC
                            No, you can draw it to the screen if you make your own 'tool'. Use the view.draw method of your tool class and you can do some pretty interesting things.
                            BUT, that requires the user to be using your tool so they can see the info you've written to the screen. Once they switch to rotate or pan or select, move, etc the data disappears. So it is also flawed.
                            All my Plugins I've written
                            • A
                              alexmojaki
                              Well, for me it's not even showing on top of the main Sketchup window. I have no other dialogs open, the only other window is Sketchup itself. And when I click on it, the dialog disappears right behind it.
                              @tig said:
                              Your test
                              if
                              Yes, I replaced the real code with the comment.
                              would be better as
                              Thanks, I'll give that a try.
                              Thanks, I'll consider that. But still not ideal, of course. Is that all then?
                              • thomthomT
                                hm... you sure you didn't use show()?
                                If you try this base bone example:
                                w=UI::WebDialog.new('test').show_modal
                                If that doesn't produce a WebDialog that keep on top of SketchUp; what OSX do you have?
                                Btw, while on topic of Webdialogs, have you seen this thread: http://sketchucation.com/forums/viewtopic.php?f=180&t=23445#p198883
                                • A
                                  alexmojaki
                                  Yes, I've seen the lost manual. What was critical to me at the beginning of the thread was that show in Windows kept the dialog on top (which isn't obvious), maybe add that to the manual.
                                  OK, I edited the wrong file when I was testing show_modal. So it works correctly. Then I discovered that the problem with my code is that for some reason when I reclick on the object to put Sketchup in focus, for some reason onSelectionCleared gets called, and then immediately after onSelectionBulkChange. I have no idea why: as far as I can see the selection never gets cleared. So the dialog was actually being closed, and then it wasn't opened again because I didn't edit @prevSelection when the selection was cleared. But now that I've done that, I'm back to the original problem: each time I click on the object to try and put Sketchup in focus, the dialog is closed and reopened and so regains focus.
                                  So now it seems my main problem is that the selection is momentarily cleared unnecessarily. In fact, I tested a bit more and found that it seems to get cleared pretty much all the time. It hasn't even got anything to do with the dialog or reclicking, onSelectionCleared gets called whenever I change my selection at all. I need to keep the definition because onSelectionBulkChange doesn't react to clicking an empty space. So I need a way to distinguish between the selection being genuinely cleared and this quirk. I considered InputPoint, but I've never used that before and I don't see how it can be used from the context of a SelectionObserver.
                                  • thomthomT
                                    hm... I've noticed that the Selection observers misbehaves: http://www.thomthom.net/software/sketchup/observers/
                                    (Btw - I have other observations I've not published yet. Available in the BitBucket repo: https://bitbucket.org/thomthom/sketchup-observers/issues?status=new&status=open)
                                    • D
                                      driven
                                      on the mac show_modal and bring_to_front appears on top of everything, so they're really the same except one returns 'true' and the other returns the object.
                                      > webdialog=UI;;WebDialog.new('blur_focus')
                                      #<UI;;WebDialog;0x110e2a48>
                                      > webdialog.show
                                      true
                                      true
                                      > webdialog.bring_to_front
                                      > webdialog.execute_script('window.focus()')
                                      true
                                      webdialog.execute_script('window.blur()')
                                      true
                                      > webdialog.close
                                      nil
                                      'window.focus()' and 'window.blur()' work with 'show', 'show_modal' or 'bring_to_front', so you can do stuff like
                                      > webdialog.set_html("Hi!")
                                      true
                                      > webdialog.set_html("Bye!")
                                      true
                                      true
                                      > webdialog.set_html("I'm going to hide!")
                                      webdialog.close
                                      true
                                      > webdialog.show
                                      true
                                      just say if I'm 'barking up the wrong tree'
                                      john
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Yup! Been there, done that, just yesterday, in fact (edited the wrong Js function and wondered why things did not change.)
                                        @alexmojaki said:
                                        Then I discovered that the problem with my code is that for some reason when I reclick on the object to put Sketchup in focus, for some reason onSelectionCleared gets called, and then immediately after onSelectionBulkChange. I have no idea why ... So now it seems my main problem is that the selection is momentarily cleared unnecessarily. ... onSelectionCleared gets called whenever I change my selection at all.
                                        This is expected. The selection must be cleared in order to receive the elements for the new selection, regardless of whether they are the same as the old selection.
                                        Sketchup::ToolsObserver
                                        The SelectionTool is tool id #21022
                                        You might get some benefit from watching the tool state (integer) changes.
                                        Also the Sketchup::Tools collection, might help.
                                        But be sure you always check that active_tool_id != 0 before attempting to access active_tool_name() (if active tool is undefined, trying to get a name string can BugSplat! SketchUp.)
                                        Not for Mac, which is where you had the Z-order problem. AFAIK, it is still MS Windows only. (Unless they've gotten it working on the Mac now?)
                                        • thomthomT
                                          Not the same. If you have a dialog opened with show then call bring_to_front then it will put the window at the top of the stack. But if you click the SketchUp window it'll appear above the WebDialog.
                                          If you use show_modal then the webdialog will never drop behind the sketchup window.
                                          • D
                                            driven
                                            I stand corrected... if acting on a previously show_modal, then bring_to_front will stay on top.
                                            ` > webdialog=UI::WebDialog.new('blur_focus')
                                            webdialog.set_html("You'll only see me flash!
                                            but I'll exist in a 'show_modal' state")
                                            webdialog.close
                                            nil
                                            webdialog.set_html("You'll see me, and because I was 'show_modal' to start with, I'll behave like a 'show_modal' dialog!
                                            However, I won't have focus, because 'window.blur()' has been called")
                                            true`
                                            My main point was that blur and focus can be set independently of the show-status.
                                            john
                                            • 1 / 2
