    Kerkthea in sketchup
    3 Posts 3 Posters 476 Views 3 Watching
      steved
      Hi all.I previously had a Kerkythea toolbar in sketchup but had my computer stolen. tried to download kerythea again and cannot get kerkythea installed inside SU so I can view the toolbars. I have attached an image of my SU plugin folder. Can anyone tell me what I have done wrong?
      Thanks guys
      "If I agreed with you on that, then we would both be wrong"
      • pbacotP Offline
        I have a file in my Plugin folder that is called "SU2kt install.txt" and it says:
        1.Please copy su2kt.rb and su2kt folder into Sketchup\Plugings
        Sketchup\Plugins\su2kt.rb
        Overwrite all older files.
        On PC the default folder is:
        C:\Program Files\Google\Google Sketchup ... \Plugins
        On MAC the default folder is:
        Macintosh HD/Library/Application Support/Google Sketchup ...... /Sketchup/plugins
        which makes sense. Usually there needs to be an ".rb" file placed directly in the Plugins folder.
        It looks like you have the whole Kerky folder in the Plugins folder. What you need in the Plugins folder is as stated above... or per your own copy of installation instructions. I have my Kerky folder in my applications folder.
        • tridemT Offline
          tridem
          Indeed, it's not good having the KT program folder inside the SU plugin.
          That's how usually the folders look like
          plugin folder (the path.txt file should be created automatically the first time you run su2kt and ask you where the kerkythea.exe file is located)
          application folder
