    [Plugin] Stepped Extrude [Updated 20121106]
    28 Posts 18 Posters 34.8k Views 18 Watching
    • rami_lpmR
      rami_lpm
      This tool allows stepped push pull.
      Pick one face, it gets extruded one step. Pick the next it gets extruded two steps, and so on.
      You can change the step height by typing it right after selecting the tool.
      It's useful when making stepped terrain models.
      As requested here http://sketchucation.com/forums/viewtopic.php?f=323&t=48651
      Now it handles contour lines as suggested by Chris.
      Thanks to sdmitch for the code to handle the moving of lines.
      RamTools_StepEx.rb
      • gillesG
        gilles
        Well done, I like it.
        • pbacotP
          Yes, very good thanks!
          In regards to Topo work as in the example--there is a CAD application that I used that would interpret the height of contours in plan by the user drawing a section line. Another idea to specify the relative heights.
          What you have here might also be useful to model site steps (the kind people walk on) that are laid out in plan but too irregular for move-duplicate creation. Just as I needed yesterday...
          Thanks again for the plugin work.
          • Chris FullmerC
            Great tool idea. Does it work with lines? If not, could you adjust it to work with lines? The user would click on a line and the script would select all connected and move it vertically by 1 unit, then 2 units, 3, etc. Same idea, I just rarely make stepped models. I deal with topo lines only and then use the sandbox tools to turn them into a TIN. Thanks!
            Chris
            All my Plugins I've written
            • rami_lpmR
              rami_lpm
              This sounds very complicated, I'll see what I can do.
              No, it works only with faces. I think I can add that, it will take some time, though.
              Thanks for trying it out.
              • Chris FullmerC
                No rush, it might be a nice feature to add if you feel like adding something. Thanks!
                • sdmitchS
                  sdmitch
                  rami, Add this code to the onLeftButtonDown def. It will handle the edges or curves.
                   best.pushpull dist,false
                  else
                   best = ph.picked_edge
                   unless best==nil
                    @clickno += 1
                    dist=@clickno*@step
                    trans=Geom;;Transformation.translation([0,0,dist])
                    unless best.curve
                     edges=best.all_connected
                     verts=[];edges.each{|e| verts<<e.vertices}
                     verts.flatten!; verts.uniq!
                     verts.each{|v| Sketchup.active_model.entities.transform_entities(trans,v)}
                    else
                     Sketchup.active_model.entities.transform_entities(trans,best.curve)
                  http://sdmitch.blogspot.com/
                  • sumasterS
                    sumaster
                    Thank you very much
                    Thank you,
                    SUmaster
                    • boofredlayB
                      boofredlay
                      Nice. A much needed tool.
                      • rami_lpmR
                        rami_lpm
                        It's updated. Thanks for that snippet.
                        • J
                          JGA
                          Great idea, thanks (again).
                          Regards,
                          JGA
                          • srxS
                            srx
                            Thanks! It could be useful for making stairs also... or SU logo ๐Ÿ˜„
                            www.saurus.rs
                            • B
                              Ben Ritter
                              Thank you Ramiro.
                                Cool! ๐Ÿ˜Ž
                                Works fine with the Multiple Offset by Sdmitch ๐Ÿ˜‰
                                  Have you the same but only for lines ? ( with no PushPull of faces )
                                  Like this
                                  only lines are moving with Stepped Extrude , and there is no creation of faces !
                                  like a creation of levels of terrain for example ๐Ÿ˜„
                                  • pbacotP
                                    Pilou, The first post claims this is possible. I haven't tried. Peter
                                      No it's draw also a face when you click a line like when you click on a face! ๐Ÿ˜‰
                                      I just want stepp the lines ! ๐Ÿ˜„
                                      • sumasterS
                                        sumaster
                                        Hi rami_lpm AND sdmitch,
                                        a Need of previous history Amount/Distance . . . .
                                        means create 2 face and use this tool and 1st face extrude 1 m. and 2nd face extrude the same amount . . .
                                        now its not working . . . . .
                                        thanks . . . .
                                        Thank you,
                                        SUmaster
                                        • bsintzelB
                                          bsintzel
                                          Simple, functional, useful and free...what more can one ask for. Well done ๐Ÿ‘
                                          I've taken obfuscating to a whole new level!
                                          • R
                                            rv1974
                                            The perfect fuse of simplicity and effectiveness.
                                            Salute to the authors.
                                            • 1 / 2
