    [Plugin] Stepped Extrude [Updated 20121106]
    28 Posts 18 Posters 34.1k Views 18 Watching
    • pbacotP Offline
      Yes, very good thanks!
      In regards to Topo work as in the example--there is a CAD application that I used that would interpret the height of contours in plan by the user drawing a section line. Another idea to specify the relative heights.
      What you have here might also be useful to model site steps (the kind people walk on) that are laid out in plan but too irregular for move-duplicate creation. Just as I needed yesterday...
      Thanks again for the plugin work.
      • Chris FullmerC Offline
        Great tool idea. Does it work with lines? If not, could you adjust it to work with lines? The user would click on a line and the script would select all connected and move it vertically by 1 unit, then 2 units, 3, etc. Same idea, I just rarely make stepped models. I deal with topo lines only and then use the sandbox tools to turn them into a TIN. Thanks!
        • rami_lpmR Offline
          rami_lpm
          This sounds very complicated, I'll see what I can do.
          No, it works only with faces. I think I can add that, it will take some time, though.
          Thanks for trying it out.
            No rush, it might be a nice feature to add if you feel like adding something. Thanks!
            • sdmitchS Offline
              sdmitch
              rami, Add this code to the onLeftButtonDown def. It will handle the edges or curves.
               best.pushpull dist,false
              else
               best = ph.picked_edge
               unless best==nil
                @clickno += 1
                dist=@clickno*@step
                trans=Geom;;Transformation.translation([0,0,dist])
                unless best.curve
                 edges=best.all_connected
                 verts=[];edges.each{|e| verts<<e.vertices}
                 verts.flatten!; verts.uniq!
                 verts.each{|v| Sketchup.active_model.entities.transform_entities(trans,v)}
                else
                 Sketchup.active_model.entities.transform_entities(trans,best.curve)
              http://sdmitch.blogspot.com/
              • sumasterS Offline
                sumaster
                Thank you very much
                Thank you,
                SUmaster
                • boofredlayB Offline
                  boofredlay
                  Nice. A much needed tool.
                  • rami_lpmR Offline
                    rami_lpm
                    It's updated. Thanks for that snippet.
                      JGA
                      Great idea, thanks (again).
                      Regards,
                      JGA
                      • srxS Offline
                        srx
                        Thanks! It could be useful for making stairs also... or SU logo πŸ˜„
                        www.saurus.rs
                          Ben Ritter
                          Thank you Ramiro.
                            Cool! 😎
                            Works fine with the Multiple Offset by Sdmitch πŸ˜‰
                              Have you the same but only for lines ? ( with no PushPull of faces )
                              Like this
                              only lines are moving with Stepped Extrude , and there is no creation of faces !
                              like a creation of levels of terrain for example πŸ˜„
                              • pbacotP Offline
                                Pilou, The first post claims this is possible. I haven't tried. Peter
                                  No it's draw also a face when you click a line like when you click on a face! πŸ˜‰
                                  I just want stepp the lines ! πŸ˜„
                                  • sumasterS Offline
                                    sumaster
                                    Hi rami_lpm AND sdmitch,
                                    a Need of previous history Amount/Distance . . . .
                                    means create 2 face and use this tool and 1st face extrude 1 m. and 2nd face extrude the same amount . . .
                                    now its not working . . . . .
                                    thanks . . . .
                                    Thank you,
                                    SUmaster
                                    • bsintzelB Offline
                                      bsintzel
                                      Simple, functional, useful and free...what more can one ask for. Well done πŸ‘
                                      I've taken obfuscating to a whole new level!
                                        rv1974
                                        The perfect fuse of simplicity and effectiveness.
                                        Salute to the authors.
                                        • I Offline
                                          icepam
                                          Thanks for a much useful plugin. I had coded something similar in AutoLisp a few years ago to do this in Autocad, precisely for stairs and contours.
                                          @rami_lpm said:
                                          @pbacot said:
                                          ... interpret the height of contours in plan by the user drawing a section line.
                                          I think this could be simpler than it sounds, maybe one of the forum's rubymasters could help out with the code. Here's how i would imagine it:
                                          Method 1, should work with lines:
                                          -User draws a line across the contours he wishes to raise and sets H=riser height.
                                          -Plugin figures if it's a generally horizontal or vertical line (is that necessary?)
                                          -Plugin finds all intersection points and makes an array ordered based on their X (or Y?) coordinate
                                          -Plugin traverses array raising each line by H x its index in the array.
                                          Method 2, perhaps this is the solution for faces?
                                          -User selects all faces that need to be raised (by window or select all or whatever... if one by one, it's just the current method)
                                          -User draws a line L through all said faces
                                          -Plugin filters out non-faces from selection and makes an array as above, ordered by X or Y coordinate of mid-point of segment created by intersection between line L and each face.
                                          -Plugin traverses and raises as above.
                                          Hope this makes sense!
                                            No possibility to add the other options? As asked in my old request here πŸ˜‰
                                            Now we have a =a + x πŸ˜‰
                                            http://sketchucation.com/forums/download/file.php?id=83670
