    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 24.3k Views 6 Watching
      So you HAVE got fc-list to work after all! πŸ˜„
      Don't you need to include 'file' in the output as well as 'family' and grep for '.ttf' because 3dText needs a /ttf and the 'family only' way might also list .otf fonts etc too, which 3dText might baulk at ?
      Something more like:
      fontList=(/usr/local/bin/fc-list : file family | grep .ttf:).split("\n").collect{|f|f.split(": ")[1].split(",")[0]}.to_a.uniq.compact.sort
      I'm not sure how you deal with the ".ttf:" - it perhaps needs some \ escaping ??
      If the 'grep' inside the MAC OS side is slower than doing a 'next unless f=~/.ttf: /' on the Ruby side, then you can add it into the 'collect' block instead...
        You got data back from fc-list using SketchUp Ruby??? ... but using a full path, that's the only change?
          fontList=(/usr/local/bin/fc-list : family ) returned nothing on my machine.
            driven
            YES... using fontList=(**/opt/X11/bin/fc-list** : file family | grep \/Library\/Fonts), but just to avoid X11 fonts, otherwise, all types [.ttf, otf, ttc] returned, work in SU [tested last weekend], so /Library/Fonts filter is OK.
            it's the core dump size that slows things down
            IF YOU HAVE IT INSTALLED...
            > t=Time.now fontList=(/opt/X11/bin/fc-list : file family `)
            fin=Time.now-t
            puts fontList.length
            puts fin
            138048
            0.055793
            nilBut,**%(#0040FF)[IF YOU HAVE IT INSTALLED...]** > t=Time.now
            fontList=(/usr/local/bin/fc-list : file family )
            fin=Time.now-t
            puts fin
            22832
            0.073191
            nil
            t=Time.now
            fin=Time.now-t
            puts fin
            5921
            0.016585
            nil`
            now I've realised the full path bit, there may be other ways without using fc-list...
            john
              You are using these paths:
              That didn't work for me (10.5). But this worked:
              /usr/X11/bin/fc-list
              Are any of the paths working across OSX versions?
                So, because I've had problems even getting the data I've ignored the fact that you've been also getting the filename and grepping out by path. What is the reason for this. So you only get fonts that works in SketchUp?
                  This worked on my machine:
                  <span class="syntaxdefault"><br />data&nbsp;</span><span class="syntaxkeyword">=&nbsp;(`</span><span class="syntaxstring">/usr/X11/bin/fc-list&nbsp;;&nbsp;file&nbsp;family&nbsp;|&nbsp;grep&nbsp;\/Library\/Fonts</span><span class="syntaxkeyword">`)<br /></span><span class="syntaxdefault">fonts&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">data</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">scan</span><span class="syntaxkeyword">(/[^;]+[;]\</span><span class="syntaxdefault">s</span><span class="syntaxkeyword">*(.*)/).</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map</span><span class="syntaxkeyword">!&nbsp;{&nbsp;|</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">','</span><span class="syntaxkeyword">)&nbsp;}.</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!&nbsp;</span><span class="syntaxcomment">#&nbsp;Some&nbsp;lines&nbsp;include&nbsp;multiple&nbsp;fonts.<br />&nbsp;</span><span class="syntaxdefault"></span>
                  Now it's just a matter of reliably finding the path on all the systems.
                    <span class="syntaxdefault"><br />def&nbsp;get_osx_fonts<br />&nbsp;&nbsp;fc_list_locations&nbsp;</span><span class="syntaxkeyword">=&nbsp;[<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxstring">'/opt/X11/bin/fc-list'</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxstring">'/usr/local/bin/fc-list'</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxstring">'/usr/X11/bin/fc-list'<br />&nbsp;&nbsp;</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fc_list&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">fc_list_locations</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">location</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">exist</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">location&nbsp;</span><span class="syntaxkeyword">)&nbsp;}<br />&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">fc_list</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">'Warning;&nbsp;Could&nbsp;not&nbsp;find&nbsp;fc-list!'<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;[]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;data&nbsp;</span><span class="syntaxkeyword">=&nbsp;(`</span><span class="syntaxstring">#{fc_list}&nbsp;;&nbsp;file&nbsp;family&nbsp;|&nbsp;grep&nbsp;\/Library\/Fonts</span><span class="syntaxkeyword">`)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">data</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">scan</span><span class="syntaxkeyword">(/[^;]+[;]\</span><span class="syntaxdefault">s</span><span class="syntaxkeyword">*(.*)/).</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map</span><span class="syntaxkeyword">!&nbsp;{&nbsp;|</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">','</span><span class="syntaxkeyword">)&nbsp;}.</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!&nbsp;</span><span class="syntaxcomment">#&nbsp;Some&nbsp;lines&nbsp;include&nbsp;multiple&nbsp;fonts.<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">uniq</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort</span><span class="syntaxkeyword">!&nbsp;</span><span class="syntaxcomment">#&nbsp;(!)&nbsp;Not&nbsp;UTF-8&nbsp;compatible!&nbsp;But&nbsp;better&nbsp;than&nbsp;nothing.<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts<br />end<br /></span>
                      driven
                      hi TT,
                      I did PM before I saw this, I would split it into 3 conditional block
                      the first would use /usr/local/bin/fc-list
                      if you revisit http://sketchucation.com/forums/viewtopic.php?f=180&t=48761&p=443899#p441686 you'll see that you don't need to grep /usr/local/bin/fc-list, because it avoids the system and X11 fonts already.
                      second choose last in find /**/bin/fc-list array, for the latest X11 version
                      third default to 'FontBook' it's on every mac....
                      john
                        Isn't fc-list on every mac?
                          driven
                          TT... don't you read PM's or the posts... [I am laughing]
                          reminds me of when you answer some of your 'clients'
                          The whole reason I went round in circles is fc=list has never been 'standard' on a mac.
                          a lot of people use to have xcode and it came with that as part of fontconfig for X11,
                          or if you have Wings3D, Gimp, Inkscape or Imagemagics you'd have it, so a few SU'ers will. but they all have FontBook it's a mac core app....
                            driven
                            TO RECAP
                            This is the fastest I can get a usable list from X11
                            if I remove .split[-2] from fontPath it uses /usr/local/bin and is twice as fast, same result... so the one could be used for any fc-list installed, without hardcoding a path.
                             fontPath=(`find /*/*/bin/fc-list`).split[-2]
                            fontList=(`#{fontPath}  ; file family | grep \/Library\/Fonts`).split("\n").collect { |f| f.split(";")[1] }.collect { |f| f.split(",")[0].strip}.to_a.uniq.compact.sort[5..-5]
                            the .sort[5..-5] cleans out the dot files at top and some other cruft the the bottom...
                            john
                            EDIT: I missed a .strip that stop them running... leading whitespace.
                            on test a couple are getting through that shouldn't
                            *** macFonts group Error! *** i = 38 chunk = 4 font = Bitstream Charter Error #<TypeError: reference to deleted Group> Error: #<TypeError: (eval):282:inname=': reference to deleted Group>
                            (eval):299
                            (eval):282
                            (eval):274:in times' (eval):274
                              I've become so confused on this whole topic. πŸ˜•
                              fontPath=(find ///bin/fc-list).split[-2]
                              That command was very slow on my mac.
                              Can you be sure this is the same on all machines? I'm hesitant to use magic numbers.
                              OSX is giving me headackes in regard to this plugin. I'm tempted to just drop it all together. Taking too much time.
                              At the moment I'm looking at first attempting fc-list, if it's installed. (Might have to do a search - so I have to cache that.) Then fall back to AppleScript and FontBook - also slow so it also needs a cache list (meaning the list won't automatically keep in sync.)
                              sigh
                              And that's not including the crashing...
                                driven
                                TT, maybe you want to move this, but
                                I was looking for a UFT8 font filter and came across a simple test code for checking console encoding.
                                I thought Ruby Console was UFT8, but it's not?
                                I made a little test script, and ran it both from console and from plugins.
                                same result from both...
                                >  msg = (`perl -Mcharnames=;full -CS -wle 'print "\N{EURO SIGN}"'`).to_s
                                 puts msg
                                 rply = (`locale`).to_s
                                 puts rply
                                 result = UI.messagebox msg, MB_YESNO
                                 if result == 6 # Yes
                                   UI.messagebox("Sketchup dosen't use UFT8, it uses \n" + rply)
                                N{EURO SIGN}
                                LANG=
                                LC_COLLATE="C"
                                LC_CTYPE="C"
                                LC_MESSAGES="C"
                                LC_MONETARY="C"
                                LC_NUMERIC="C"
                                LC_TIME="C"
                                LC_ALL=
                                for comparison Terminal.app results
                                %(#008000)[johns_iMac at upstairs in ~
                                $ locale
                                LANG="en_US"
                                LC_COLLATE="en_US.UTF-8"
                                LC_CTYPE="en_US.UTF-8"
                                LC_MESSAGES="en_US.UTF-8"
                                LC_MONETARY="en_US.UTF-8"
                                LC_NUMERIC="en_US.UTF-8"
                                LC_TIME="en_US.UTF-8"
                                LC_ALL="en_US.UTF-8"
                                $ perl -Mcharnames=:full -CS -wle 'print "\N{EURO SIGN}"'
                                john
                                  It's UTF-8.
                                  Test example:
                                  'ΓΈ'.unpack('C*')
                                  Returns:
                                  [195, 184]
                                  Which is the correct byte values in UTF-8 encoding.
                                  195 indicate the Latin1 page 184 points to ΓΈ on that page.
                                  Don't know what the data you got from them commands where. But just by looking at the test data byte per byte you can tell it's UTF-8.
                                    driven
                                    yes that does return correctly,
                                    which is why I can't understand why some thing get lost in transition...
                                    same font Stix(NON-Unicde)
                                    Top happens from Ruby Console as well as WebDialogs
                                    Bellow is the Built in Tool
                                    john
                                      hm... I've not have any problems with it.
                                      Do you see this in the 3d text plugin I sent you?
                                        driven
                                        Top one... I was being discrete
                                        ` > a = "2ζ’–μ£Ί".unpack('C*')
                                        b = a.pack('C*')
                                        c = puts a.inspect
                                        puts b.inspect
                                        [50, 230, 146, 150, 236, 163, 186]
                                        "2ζ’–μ£Ί"
                                        nil`
                                        the puts should read [0, 50, 100, 150, 200, 250] "2ζ’–μ£Ί"
                                          Why are you using "C*" in the unpack and pack - doesn't that extract a character as an unsigned integer.
                                          Shouldn't it be "U*" - which extracts UTF-8 characters as unsigned integers ?
                                            Because I actually want to see each byte. Not the Unicode ID.
                                            • 6
                                            • 5 / 6
