    Material color change don't work
    extensions
    3 Posts 2 Posters 359 Views 2 Watching
    • K
      Kreativ3D
      Hi!
      I'm using free Maxwell Render. I'm confused because when I'm changing the color of a material, it isn't changing in the rendering!? What have I done wrong? Preciate some help!
      • jason_marantoJ
        jason_maranto
        If you are changing a simple colored material it will work in "real-time", however if you are attempting to colorize a texture then you will have to manually refresh the scene in FIRE or the changes will not be shown.
        The reason why is a colorized texture has be be re-exported to the engine (as a new texture), whereas a simple "color" does not.
        Any time you make any changes that have to do with changing textures you will have to manually refresh.
        Best,
        Jason.
        • K
          Kreativ3D
          Thanks for the reply! I have just changed the color to be darker. It's not a texture, just plain color material. And I have pressed the refresh button several times, but it still render the old color!? Help!?
