    Dimensions box only working 50%
    5 Posts 3 Posters 268 Views 3 Watching
    • W Offline
      WorstCases
      Hello folks.
      I am trying to learn the basics of SketchUp and am stuck at a very basic thing.
      I am using SketchUp 8.0.15158 on Vista
      Example:
      I'm trying to draw a 4x8 rectangle. I click rectangle, start drawing, hold mouse button and start typing [4',8'] and hit enter.
      What I always end up with is a 4xWhatever dimension. Where it should be 8 is wherever my mouse was.
      There must be something I'm missing. Something very simple...
      • pbacotP Offline
        Let go of the mouse button. Then type. For many tools in SU: finish the operation, then immediately type new dimensions or other input.
        • W Offline
          WorstCases
          Thank you for the Tip.
          Still: If I draw a box and type 4',8', the size will change, but is not 4x8 if I put the measuring tape to it. That's weird!
          • cottyC Offline
            cotty
            It depends on the language if you have to type 4;8 or 4,8. Did you try the other one too?
            my SketchUp gallery
            • W Offline
              WorstCases
              Thank you very much!
              I have to use ";" instead of ",".
              Simple - I knew it! Still bothered me since days!
              Again: Thank you!
