    Rotation
    7 Posts 4 Posters 424 Views 4 Watching
    • E Offline
      erzane
      I would like to rotate the B line of my component in blue to be 100% straight with the A line
      I use the rotate tool but I dont know how to rotate it automaticly straight as the A line
      I must do it with my eyes and it's not 100% straight
      http://imageshack.us/a/img560/9565/capture02b.jpg
      http://imageshack.us/a/img203/8613/capture02copie.jpg
      thanks
      • sdmitchS Offline
        sdmitch
        Use the Tape Measure Tool to create a guide line parallel to edge A through an end point of edge B then rotate edge B to the guide line.
        http://sdmitch.blogspot.com/
        • E Offline
          erzane
          hi
          how looks tape measure tool ?
            This tool 😉
            From a vertex it draw a an helper line + a cross point
            From a line it draw a parallel helper line
            And if you measure something and input your own measure it will resize all your objects!
            So put each object in group or component if you want just resize one object!
            • cottyC Offline
              cotty
              The fastes way would be to use one of the standard inferences (On Edge, On Axis, Parallel to Edge, ...) while rotating:
              my SketchUp gallery
                And for maximum inference don't miss to use the fabulous one
                Fredo Scale by Fredo 6
                http://sketchucation.com/forums/download/file.php?id=87785
                http://sketchucation.com/forums/download/file.php?id=87786
                • E Offline
                  erzane
                  sorry guys I totaly forget this post,
                  I just did that measure last day.
                  so it helped me a lot to resolve my pending issue
                  thanks 😉 and sorry again for the delay
