⚠️ Libfredo 15.4b | Minor release with bugfixes and improvements Update
Parallel view rotate
9 Posts 4 Posters 1.1k Views 4 Watching
    sketcpeppe75
    hello all. I noticed that The instruments view of sketchup are a bit limited (or I can not seem to use them properly). I would like to turn the plan of an apartment at 90 ° to the z-axis maintaining the parallel projection so as to have the long side horizontal and optimize the operation of the export 2d jpg. I tried the option orbit but of course I leave the plan view. I tried nurgeorbit useful but only for perspective views. I say "rotate the object" ... but I can not rotate a building model to orient the view you want for each apartment. some idea or some plug? thanks friends
      charly2008
      Hi Guiseppe,
      Can You even upload the Skp file?
      Charly
        charly2008
        In general, the rotation is working without problems. You just have to select the entire model.
        • G Offline
          gilles
          Have a look at this:
          http://sketchucation.com/forums/viewtopic.php?t=35499#p313105
          I didn't try it, but it seems to be what you are looking for.
            sketcpeppe75
            hello charly2008, as I said, I could rotate each time the model, but it is not productive. so I need to only rotate the view so that you have the relevant section (1 apartment of ....) aligned to import jpg with the best resolution. 😉 Thank you very much anyway. gilles is always the kind to help me and I thank him, I look at her advice and let you know. 😉
              sketcpeppe75
              done! works. 😍 thank you gilles. I had missed! tig is a magician ... has an answer for everything 😉
              • G Offline
                gilles
                  cotty
                  some more possibilities:
                  • Quick camera rotate 90°
                  • Camera tools ("roll camera" is only one of the helpful tools)
                  my SketchUp gallery
                    sketcpeppe75
