    2D DXF export without a pro version?
    8 Posts 5 Posters 1.1k Views 5 Watching
    • HelmiH Offline
      Helmi
      i wonder if there's a good way to export 2D DXF files out of sketchup like it is possible with the pro version but with a (free or paid) plugin only on the free version of sketchup?
      I'm drawing different stuff that i'd like to export for milling and to transfer it to the CAM software DXF would be the only useful format.
      Thanks for helping.
      Frank
      • locoL Offline
        loco
        Maybe this? http://sketchucation.com/forums/viewtopic.php?t=40773
        Windows 10, gpu rtx 3060 12gb ram, cpu AMD Ryzen 5 5600X 64gb ram, SketchUp 2022, Twinmotion 2022. My Little Tutorial
        • HelmiH Offline
          Helmi
          I've tried that but it produces broken objects in my cases with open shapes and other stuff - even on simple objects.
          • HelmiH Offline
            Helmi
            I just checked the STL/DXF-Exporter from guitar-list.com once again and this time it worked for the object i now had (which is rather simple) - i will keep an eye on that. If you don't know the plugin, it's here http://www.guitar-list.com/download-software/convert-sketchup-skp-files-dxf-or-stl
            • locoL Offline
              loco
              Nice find, glad its worked out for you 😉
              • olisheaO Offline
                olishea
                I use SU6/7 with a DWG/DXF exporter! Works fine every time. Cheeky I know but I don't like they way they just updated SU and removed this really important feature.
                oli
                • srxS Offline
                  srx
                  You can use Pro for 8hours for free. If U use it only for exporting dwgs, it should be enough for 8*60min/3min=160 exports, year, two, or 3? 😎
                  www.saurus.rs
                  • G Offline
                    gioglog
                    try this extension that works on sketchup make too:
                    http://extensions.sketchup.com/it/content/skema-2d-projection
                    mybe does wat you are looking for 😄
