    The frustration that is Copy along path
    20 Posts 4 Posters 991 Views 4 Watching
      matsuo_lano
      Hello all,
      I've been getting a bit frustrated with the plugin Copy along path. I want to align a segment to a welded path (as you can see in the attached files). Help would be greatly appreciated!
      Path copy failure 1
      Path copy failure 2
      You try to rearrange me 'till I'm sane
        Have you used this one ?
        by Rick Wilson ร  Smustard
        There are 2 options, by spacing or by node spacing
        Else post your skp file in V6 (save as .../ V6)
          matsuo_lano
          First of all, thanks for the quick reply!
          I'm using the PathCopy script from Smustard.com. As requested I've attached the .SKP file with a path and segments I would like the path to follow. As a side-note I would like to add that the distance between the two segments isn't set yet ๐Ÿ˜‰
          Cheers!
          copypath.skp
          • gillesG Offline
            gilles
            What you need is Component Stringer:
            http://sketchucation.com/forums/viewtopic.php?t=23616#p200751
            See this little tutorial.
            minitel compatible
            • gillesG Offline
              gilles
              Sorry I forgot the link for Bezier spline/
              http://sketchucation.com/forums/viewtopic.php?t=13563#p100509
                matsuo_lano
                Thank!s guys, that was most excellent!
                Now let's see if I can do it ๐Ÿ˜‰
                  Gilles was more speed than me! ๐Ÿ˜‰
                    Thx for the "Minitel"! ๐Ÿ˜Ž
                    • gillesG Offline
                      gilles
                      Be my guest. ๐Ÿ˜„
                        matsuo_lano
                        Well, I must be doing something completely wrong... I followed the instructions step by step, but the components all stick out!
                        copypath_V6.skp
                          matsuo_lano
                          It should work now!
                          • gillesG Offline
                            gilles
                            You did not set the component axis correctly, in component stringer the blue axis of the component will follow the normal of the edge.
                            Look at scene five in my file.
                              you have not saved "save as / V6" ๐Ÿ˜‰
                              I can't help you ๐Ÿ˜„
                                I was speaking about your file error error of course ๐Ÿ˜‰
                                I never understood why Chris has made this crazzy orientation! ๐Ÿ˜ฎ
                                It's an headache at each time for put he new axes! ๐Ÿ’š
                                • gillesG Offline
                                  gilles
                                  +1
                                    matsuo_lano
                                    Is there a way to also select the position of the blue axis? Since it gets placed automatically.
                                    Edit: nevermind, I finally did it ๐Ÿ˜„
                                    Thanks all!
                                    • gillesG Offline
                                      gilles
                                      @chris fullmer said:
                                      Hi John, I set is up so that the blue axis in the component lines itseful up with the line spegment it is being placed on in the path. That is as much as I control directly in the script. The x and y axes are determined through what SU calls "an arbitrary axis rule." Digging into this, it appears that once I set the blue axis, SU forces the component's red axis to lie flat on the x,y plane. Then the component orients itself so that the green axis is pointing in a positive direction (always pointing slightly upard, or completely upward if the path being followed is flat on the ground).
                                      So, if your path is flat, then the blue will follow the segment it is to stetch over. And the green will point upwards in the model's blue direction.
                                      But once your path gets off the flat x,y plane, the it gets a little trickier to guess how the pices will orient themselves.
                                      Sorry thats not much help,
                                      Chris
                                        matsuo_lano
                                        I've discovered that 1 segment of my segmented polyline is a bit smaller than the other 31 parts. Is this because I use version 8? Or do I just need to update?
                                          bjornkn
                                          Well, it's the same orientation as used by glued components, and also used a lot for follow-path animation.
                                          • gillesG Offline
                                            gilles
                                            http://sketchucation.com/forums/viewtopic.php?p=414333#p414333
                                            you have an old version of BZ__Segmentor.rb
                                            see this post.
                                            to drop into the BZ_Dir_14 folder
                                            http://sketchucation.com/forums/download/file.php?id=90404
