    [Code] Transforming in custom coordinate systems
    3 Posts 2 Posters 319 Views 2 Watching
    • thomthomT
      Here's a snippet that I had to bend my mind to understand. I wanted to scale entities along the axis of the currently open group or component using one transformation on the entities.
      Entities in SketchUp are transformed in global coordinates so I had to transform my local scaling transformation into one that worked in the global space.
      I couldn't get it working for a long time, until I re-read this Wikipeadia article:
      http://en.wikipedia.org/wiki/Transformation_matrix#Composing_and_inverting_transformations
      (This is called the Associative property.) In other words, the matrix of the combined transformation A followed by B is simply the product of the individual matrices. Note that the multiplication is done in the opposite order from the English sentence: the matrix of "A followed by B" is BA, not AB.
      <span class="syntaxdefault"><br /></span><span class="syntaxcomment"># This will scale selected face 2x in the X direction<br /># of the currently open group / component<br /></span><span class="syntaxdefault">face </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">local_coords </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edit_transform<br />local_scale  </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">scaling</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> 2</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 1 </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform_entities</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> local_coords </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> local_scale </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> local_coords</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">inverse</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> face </span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
      http://stackoverflow.com/questions/12753314/how-to-scale-along-a-vector-in-one-transformation
      • renderizaR
        renderiza
        This solves a big problem since at least for me, maintaining the local axis of the object I want to scale is important. Thanks for this great share!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • thomthomT
          😄 Glad it helped.
          I spend a loong time on that - I just couldn't warp my head around what was going on. The key was the quote from the Wiki article. Everything makes so much more sense now.
          Figured I'd post it here to remind myself.
