    [Request]Snapshot With File Name button
    15 Posts 3 Posters 3.1k Views 3 Watching
      simon le bon
      Each time I surf through my skp directory searching to open the right file, especially when I have saved it as an incremental set, I regret to not have taken the time to have stored side by side a snapshot with the same file name in order to scan quickly all my models with a simple picture viewer. So I have to open each file one by one into SU: it can be quickly a mess 😐
      A plugin that would be able to take in account Su's snapshot engine to save by default a picture with the same file name, into the same directory would be very great I'm telling to myself each time.
      Beginning with Blender I see that this option exists so nicely ( + option of the total UI snapshot or only the active window ) 👍 👍
      http://i274.photobucket.com/albums/jj245/Spendauballet/Blender/SaveScreenShotBb_00.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/Blender/SaveScreenShot_002.jpg
      Is that take some sense for anyone else ?
      Cheers,
      simon
        Aerilius
        Incidentially I just had made a script for large thumbnails (very large). It probably won't work for you, but I could just extract and modify the relevant code.
        My script automatically exports a large thumbnail every time when a SketchUp file is saved (linked to the file name of the opened skp). Would this be what you want, or do you need the option to set the filename manually? Does your incremental backup system work that way that the file that you are working on is the one you want the snapshot for?
        • G Offline
          glro
          @aerilius said:
          Accidentially I just had made a script for large thumbnails (very large). It probably won't work for you, but I could just extract and modify the relevant code.
          large thumbnails are better, because on small thumbnails you hardly see any details if it is a whole model
          possible to set a parameter for the size of the thumbnail?
          a common folder for all the thumbnails is a good idea, because this way you don't have to look into many folders; if what you are looking for exists, it must be there...
            simon le bon
            Dear Aerilius,
            thank you for the reply
            Your script sounds very good to me ☀ 👍 👍
            Very large thumbnails are enough in quality because the purpose would be to identify clearly and quickly the content of each .skp file. Your video shows that this goal is achieved. ->+++
            Re: I like very much the models' background made with a transparent alpha channel 👍
            ../exports a large thumbnail ../..(linked to the file name of the opened skp)
            Is that means that we can't manage picture files ? (copy, change the name, put them in the desired folder, print them etc.. ?
            If this is right, this is (IMO) the bad point.
            The possibility to adapt each personal workflow would be very welcomed. 😉
            Yes! 😄
            Related topics and scripts I have found (where we can see your participation 😉 👍 )
            Thumbnail Extractor
            http://sketchucation.com/forums/viewtopic.php?f=323&t=31438
            [Plugin] Upload model with custom thumbnail
            http://sketchucation.com/forums/viewtopic.php?f=323&t=37667
            Does your script is shared somewhere ?
            ++,Simon
              Aerilius
              I meant the image's name is determined from the model's file name, if that is ok then the script could even save the snapshot automatically. You can then, of course, do what you want with the image.
              I have script that is ready soon (maybe only tomorrow).
                simon le bon
                Nice nice nNice !!* ☀
                Happy that these large thumbnails are manageable true pictures, not like those natively embedded with .skp files 👍
                Re:
                the so nice and powerful XnView application is able to achieve a contact sheet very easily +++
                http://www.xnview.com/fr/index.html
                http://portableapps.com/apps/graphics_pictures/xnview_portable
                +++, simon
                  Aerilius
                  Can you test the plugin: http://sketchucation.com/forums/download/file.php?id=94646
                  • G Offline
                    glro
                    file deleted?
                      Aerilius
                      Try it now?
                        simon le bon
                        Hey Hey Ae,
                        That sounds pretty good 😍
                        I never thought you were going to make such an accomplished tool 😮 total thanks, total respect 👍 👍
                        everything seems to be there to offer a 100% handy plugin: (bravo for -1 increment 👍 )
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Aerilius_Snapshot_001.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Aerilius_Snapshot_002.jpg
                        It seems that there is a problem with the Snapshot Settings Apply Button which don't save the settings. So for the time being your plugin works with default options. Pictures are save in: PNG 512x384 into the skp folder.
                        (the background is not transparent but take the color of style ground _ no axes)
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/DinoProxy_00-1.png
                        (compared with a snapshot taken with FastStone Capture)
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/DinoProxy_00-1_FC.jpg
                        +++ Simon
                        • G Offline
                          glro
                          @aerilius said:
                          Try it now?
                          yes, i could download the file
                          seem to work fine
                          i don't understand the meaning of "save the name-1" and "save the name "+1"..
                            simon le bon
                            Ok,
                            I know from where come the problem.
                            As SU7 is still my main Su, I had dezipped the .rbz file and copied the files into Su7 Plugin directory.
                            But it is a plug made for SU8 . I have installed it in my fresh SU8, then it works perfectly:
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Aerilius_Snapshot_00.png
                            Bravo pour ce magnifique travail 👍 👍 👍
                            😉 😄 😄 😎 simon
                              Aerilius
                              That's good to hear. I didn't think there could be something that would not work in SU7, but as you see it does not only not apply the settings, but it doesn't load the default settings (it's empty). I will look into it..
                                simon le bon
                                That means that you can take not only one but a series of snapshots of the same model. They take the same file name + an incrementation. Basically you are going to use "save the name "+1"
                                Aerilius_Snapshot.skp is then accompanied with
                                The "save the name-1" is less evident. Previously I thought it was adding at the end of the file name a decrementation -1 -2 -3 etc..
                                This was very foxy, using it with an already incremental set of skp
                                if this was the skp set,
                                Aerilius_Snapshot1.skp
                                Aerilius_Snapshot2.skp
                                Aerilius_Snapshot3.skp
                                The Snapshots set was
                                etc...
                                But "save the name-1" don't work this way. It decrements an existing incrementation. And when there is no digit at the end of the file:
                                Aerilius_Snapshot.skp gives
                                Aerilius_Snapshot-1.png and after "save the name-1" overwrite this picture.. ❓ 😒
                                About incrementation, there is the classic method and a better foxy one, developed here into the forums, but impossible to me to find it back (I was sure I had bookmarked it 😞 )
                                *>The Classic one consists to save your WIP model with an incrementation. The most up to date one takes the higher number.
                                Basically it is the set I was using above
                                Aerilius_Snapshot001.skp
                                Aerilius_Snapshot002.skp
                                Aerilius_Snapshot003.skp
                                disadvantages are: you can never be sure what really is the last file. Perhaps you worked in the office and at home, perhaps you have some files stored in another folder, perhaps a collaborator has worked on a new version, etc. ..
                                *>The foxy method works with the file option " Save a copy as "
                                This option offers to save the file you are working on with an incrementation but without updating the name of your model on screen.
                                Using this option, the last and most updated model can be always the first one ❗ ❗ 💚 🤓
                                Aerilius_Snapshot_00.skp is saved and also a "Save a copy as" is saved
                                Aerilius_Snapshot_001.skp
                                At the next step of the drawing, as you are always working on the "00" one, another "Save a copy as" is saved:
                                Aerilius_Snapshot_002.skp
                                etc..
                                Very clever indeed no ?
                                @Aerilius
                                What I can regret is that this "Save a copy as" doesn't generates a Snapshot when Autosave is checked.
                                😄 simon
                                  simon le bon
                                  [highlight=#ffff80:4081wmop]this thread is now closed.[/highlight:4081wmop]
                                  the script has found a new home
                                  and discussion can be pursued there.
                                  **[beta[Plugin] Snapshot – (0.1.0) — 02.10.2012
                                  by Aerilius » Tue Oct 02, 2012 8:12 pm**]
                                  http://sketchucation.com/forums/viewtopic.php?f=323&t=48215
                                  ☀ ☀ Simon.
