    Dwg dxf and 3ds model face lost
    2 Posts 2 Posters 607 Views 2 Watching
      aigars007
      Hi!
      Downloaded model (from net) looses several,most of faces, there is only lines. What could fix this problem. I tried to view hiden geometry, makeface plugin, but nothing helped. Please recommend me something.
      Picture of example:
      http://imageshack.us/photo/my-images/35/25637687.jpg/
      Thanx
      • AnssiA Offline
        Anssi
        What import unit did you use? The SketchUp Pro importer doesn't recognize the unit that has been used in the model you try to import, but you will have to provide the information yourself, via the Import Options that are hidden behind the Options button on the Import File dialog box. If you are inadvertently importing the model in millimeters or centimeters instead of Feet or Meters, it might result to too small faces that SU is unable to fill. An Imageshack image does not tell us much about the original DWG file so if you could post that there might be more to be learned from it.
        Anssi
