    Tool.onCancel - Reselect tool?
    9 Posts 5 Posters 1.4k Views 5 Watching
      https://developers.google.com/sketchup/docs/ourdoc/tool#onCancel
      1: the user re-selected the same tool from the toolbar or menu.
      I can't seem to get reason code 1 to trigger. Only 0 and 2.
      I thought I'd used it before - but I'm unsure. 😕
        Test snippet:
        <span class="syntaxdefault"><br />class MyTool<br /><br />  def activate<br />    puts </span><span class="syntaxstring">"activate; #{self}"<br /></span><span class="syntaxdefault">  end<br /><br />  def deactivate</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> view </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    puts </span><span class="syntaxstring">"deactivate; #{self}"<br /></span><span class="syntaxdefault">  end<br /><br />  def onCancel</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">reason</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> view</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    puts </span><span class="syntaxstring">"MyTool was cancelled for reason #{reason}"<br /></span><span class="syntaxdefault">  end<br /><br />end<br /></span>
        • fredo6F Offline
          fredo6
          Never got code 1 either. So I usually only test 0 or not 0
          Fred
            Aerilius
            Is 1 (technically) possible?
            Do "radio" toolbar buttons trigger an action if the current state is not changed?
            Do toolbar buttons in the OS X version behave the same way?
              You can click a menu or toolbar button that activates a tool. It does triggesr the action and activates the tool again, but it deactivates the tool instead of calling this event.
              • Dan RathbunD Offline
                Dan Rathbun
                👿 (Devil's Advocate)
                Are you dealing with a single re-usable Tool instance ?
                Or does the command create a new Tool instance each time the menu item is chosen ?
                I'm not here much anymore.
                  Either way - I'm unable to trigger that event.
                  • eneroth3E Offline
                    eneroth3
                    This seems like a documentation error. However when re-selecting a tool the deactivate and activate methods seems to be called right after each other so maybe comparing a timestamp can be used to detect when a tool is re-activated.
                    My website: http://julia-christina-eneroth.se/
                    • fredo6F Offline
                      fredo6
                      That's what I do, including for simulating a double-click on icon.
                      However, you cannot avoid the calls to activate() and deactivate(), just shortcut them.
                      I just realize that, should Trimble fix this issue, there could be some regression in my scripts, because I only test status 0.
                      Fredo
