    How to deform ovalish object
    70 Posts 5 Posters 9.9k Views 5 Watching
      If you flat the "rectangle" some faces around it will be deform too πŸ˜‰
        rumcajs
        Pilou, I have opened the document, selected the object and checked the window Soften Edges. There are 0Β°. So it is really not object with curved faces. Maybe there some conversion happened without me to be aware. Strange. All lines are no dashed no, but I don't remember that I would do some conversion.
        So there is not a way how to arrange two planes on the way, they to be on the same plane?
        http://i48.tinypic.com/fw6cty.png
          kill all segments where is the rectangle
          draw the rectangle and fill the holes around it with new segments
            rumcajs
            Do you know
            http://forums.sketchucation.com/viewtopic.php?f=10&t=9011
            cleanup.rb?
            This is not exactly what I need, but similar and interesting.
              Do you know Clean Up ?
              You have a better one with the same name Clean Up by Thomthom πŸ˜‰
              If you use the previous Projection by Didier Bur, It's a game's boy to make parallal in any direction with it! πŸ˜‰
              and any number just redraw one from the last
              http://forums.sketchucation.com/download/file.php?id=93618
              or this one Edge tool Divide face by thomthom
              [flash=560,315:q55w7sw4]http://www.youtube.com/v/hM7t6t1cCkY[/flash:q55w7sw4]
                rumcajs
                I did it in different way:
                http://i47.tinypic.com/u8sjc.jpg
                Side view:
                http://i49.tinypic.com/5x0jr8.png
                But it is slow work. It took me few minutes to make the lines parralel. Then I used Created faces tool from utilities.
                You see that it is possible to do it. Hence now I need only plugin to make two lines parallel. Or 2x2 parallel. Is there some for it? I did it just with my own estimation (just observing/comparing) because I don't the technique to do that accurarely.
                  rumcajs
                  If you use the previous Projection by Didier Bur, It's a game's boy to make..
                  Did you wanted to say boy's game?
                  The guy does nice plug-ins, nice icons and it look really useful in practice. I only had really big problem to understand his English in the video so I capture 4% of the content.
                  See the "Co-linear Edges" - this look like this toy could do the job I need. Don't you think? Thanks for link.
                  Do you understand how the to control the colinear tool?
                  What I must to do if I want to make the two lines of the face paralel? (same image as above). I try and it nothing did to my model...
                    for the the parallal edges πŸ˜„
                      rumcajs
                      TGI3D - cross section tool : error: Cannot resolve cross seciton.
                      This problem can occur, when the program has has some dilemma. In the tutorial with wine glass, there is a cylinder and the instructor deleted at least top of the cylinder. In the case, that I create cylinder, which top is different shape or different angle then the bottom, than this problem will occur. The solution would be simple. Either delete top of the cylinder, or bottom, or (maybe), to draw one more circle on the face of the cylinder - I would use Tools on surface.
                        rumcajs
                        To deform faces, I found very useful, fast and simple to use this tool:
                        TGI3D: move
                        http://i48.tinypic.com/ve3typ.png
                        It is much more better then LSS deformation functions which are too slow (and create extra group, which is not needed in my case)
                        • 4 / 4
