    Sketchup 8 crashing repeatedly
    8 Posts 7 Posters 874 Views 7 Watching
      sanjeevkmishra
      HI,
      I ve been working on a interior project lately and m facing a serious problem. My sketchup file is crashing repeatedly and unable to work on the same file. I can work on other file bit on that particular file. The size of the file is around 170 MB which I dont hink would be issue. Also ve noticed that sketchup using too much of my comp memory. I ve been working on a mack book pro.
      Need really your input guys as how to recover my file. thnx.
      Rgds,
      Sanjeev
      • kenK Offline
        ken
        I have notice this also. I have determine that it occurs when using the obit or move tool. I see a slight delay and the program will shuts down. Now when I notice this slight delay, I head for the select arrow and sometimes this seems to stop the crash. The esc key does not prevent the shut down.
        However, I have know way of knowing if Sketchup was going to crash, or I was just nervous. Also this crash appears to occur if I haven't saved the project. So now when I know I am going to do a lot of obit and moving, I use the Crtl-S, and save the project. The program has never crashed if I use the Crtl-S at a rate of a save every one to two minutes.
        I also notice if I start a new project and I don't save this new project and just start working this problem occurs relatively soon.
        I am trying to determine if this occurs when I try to use the obit or move at the same time that Sketchup is doing a auto file save.
        Ken
        • G Offline
          gigglesP
          :/..... ive been experiencing the same problem with sketchup 8 pro n im running it on my mac OS x snow leopard
          if the files/projects exceed 120 MB they start crashing they crash occasionally wen u open them again they crash each time u try to rotate they crash wen u import something n they crash if u want to export the project on warehouse
          they also crash wen u try to pan or edit poly/explode component or group. plzz i need help i need to know how to fix this problem... u can also mail me at knzarshad@gmail
          • bunnyackB Offline
            bunnyack
            170 MB is pretty large. Depending on your computer, it could make SU crash, especially when autosaving. Try purging the model and using components as often as you can.
            • KrisidiousK Offline
              Krisidious
              170 megs is a huge SU file... You may be knocking on the backdoor of the program's capability.
              By: Kristoff Rand
                driven
                SU will try to dynamically update the 'Components Window' and 'Outliner Window' if they are open, it can really play havoc on mac's cpu usage, try and keep any extra windows closed until you actually need them, then close them after...
                may not be your issue but it's a known problem.
                Mountain Lion seems to handle larger models much better.
                john
                  Krisidious
                  "SU will try to dynamically update the 'Components Window' and 'Outliner Window' if they are open, it can really play havoc on mac's cpu usage, try and keep any extra windows closed until you actually need them, then close them after..."
                  I've noticed that on PC with large models too. I keep mine closed minimized until needed.
                  By: Kristoff Rand
                  • TommyKT Offline
                    TommyK
                    I can report that having the Components Window pane closed while fiddling with the Outliner dramatically reduces the likelihood of crashes. I had been getting crashes in relatively small models too, so I think there is a problem with the code somewhere.
                    I use a Mac also.
