    Trigger ruby on SU8 model changes
    3 Posts 2 Posters 305 Views 2 Watching
    • K Offline
      krisjaniszakis
      Is there any one who has answer to question.
      How to catch (on the fly) with Ruby script any changes(drawing, painting) that user is doing in active model.
      I basically don't care what he is doing I need to know that he is doing something to model.
      Krisjanis
        Probably use the transaction observer - triggers when something is added to the undo stack. But not that a transaction != operation. Many transactions trigger in between an operation. And it triggers A LOT!!!! So be very careful with that you do there. You can esily slow down SU. But if you set a simple boolean ( @changed = true ) you might be ok. But you should profile this to be sure.
        Also - never modify the model at these events - that's begging for a bugsplat.
        • K Offline
          krisjaniszakis
          Thanks it helped.
