    Select all faces facing a road
    9 Posts 3 Posters 522 Views 3 Watching
      ryangarnett
      Hello All,
      I was wondering if there is a way, or a plugin, that will select all faces that face a road. For example, if I have a series of rowhouses that face a road, is there a way to just select the road facing faces? I would be ok with drawing a temporary line that would represent the road, if that is needed for the selection process. I have attached an image of the sample rowhouses and the road orientation.
      Thanks...
      • sdmitchS Offline
        sdmitch
        I imported your image and drew the outline of the row houses, pushpulled the up, drew a single generally down the road, selected it and ran the following script
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        edg = sel.first;sel.clear
        faces = ent.select{|f| f.class==Sketchup;;Face}
        for f in faces
         fp = f.bounds.min
         pp = fp.project_to_line edg.line
         norm=f.normal;vec=fp.vector_to pp
         sel.add f if norm.angle_between(vec) < 45.degrees
        which produced this result where only the front faces are selected.
        http://sdmitch.blogspot.com/
          ryangarnett
          Thats awesome. Thank you. I am going to test this.
          Thanks again.
            ryangarnett
            Did you run this from the Ruby Console? I haven't run scripts within SU before, so this may be a really dumb question.
            • sdmitchS Offline
              sdmitch
              No not the Ruby Console but from Ruby Web Console which is a plugin that opens a window that allows you enter and execute code.
                ryangarnett
                Thank you. I was doing that with no results, but it was because my buildings are Groups. I suppose I will have to ungroup them in order to select the face?
                Thanks again.
                • mitcorbM Offline
                  mitcorb
                  Good job, Sam: 👍 👍
                  I think you might be dangerous.
                  • sdmitchS Offline
                    sdmitch
                    Dangereous? You have no idea.
                    Ryan, I can add code so groups and/or components can be checked. The code previously posted was just a quick and dirty effort to show how it might be done.
                      ryangarnett
                      Thank you Mitch, I really can't thank you enough.
