    Hillside sunset
    25 Posts 12 Posters 4.0k Views 12 Watching
    • D
      davidh
      Attached is a sunset NPR ,using the same building as used in the TROPICAL images.The house and grassy hillside was rendered in Thea with additional vegetation and the background added in photoshop.The original image was 3500 pixels wide and was reduced to upload here so I have attached a cropped part of the original image to show the detail.
      • srxS
        srx
        Grass looks fantastic! "Even better than the real thing". Could you please share your brush settings?
        www.saurus.rs
        • D
          davidh
          The main green grass is 3d rendered in Thea using the instance tool to populate the area.
          The other grass added in photoshop(the light coloured grain/wheat grass are actual .pngs of grass from "Digart" Vegetation which are dragged and dropped into the image.I cant upload the Digart grasses due to licencing issues but here is the website I purchased them from:
          http://www.gardenhose.com/
          • srxS
            srx
            Thanks Davidh. I guess it is the best way - to combine Thea instances and post add vegetation for more natural look.
            www.saurus.rs
            • DanielD
              Daniel
              Beautiful
              My avatar is an anachronism.
              • boofredlayB
                boofredlay
                I can feel the soft heated breeze on my cheek as I walk through the grass. Well done as usual sir!
                • J
                  jsmith
                  Just incredibly beautiful
                  • D
                    davidh
                    2 Versions using Theas Relight facility to render out a bright summer evening and a slightly dark evening.
                    • cheddaC
                      chedda
                      Dayum Thea is looking tempting !
                      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                      • D
                        davidh
                        A complete Thea render except for the birds and the colour overlays/toning done in photoshop.
                        • D
                          davidh
                          Another view ,this time with some additional vegetation added in photoshop(like the first image all green grasses and white flowering plants are straight from Thea,also the trees, and the light grain grasses are photoshop.)
                          • D
                            davidh
                            A couple more with different colour tones
                            • HumpmetwiceH
                              Humpmetwice
                              We need a real big like button! 💭
                              Very nice images, one day I will love to be able to do something like that!
                              • Bryan KB
                                Wow. 😲
                                • D
                                  davidh
                                  A different sky with different lighting
                                  • D
                                    davidh
                                    A different light/hdri setting.
                                      I'd really like to see the raw Thea output to appreciate the level of PP involved.
                                      These are stunning.
                                      • D
                                        davidh
                                        Thanks Rich,these are pretty much the raw Thea output except for some colour toning or minimum, and I mean minimum, foreground additions.(these would be any light/white coloured grain/wheat grass,if they are not there,then its just colour toning)
                                        I have attached an NPR of a new view,but the only reason its NPR is because its still rendering(all these images are saved from the interactive mode)and is quite grainy.
                                        I often use these grainy images to set up my final image and if I am not happy with the final grain-free render than I use these for my NPRs where I will change the sky,background,add water etc.
                                          I was expecting a very stripped back render. I wasn't expecting that the foreground was actually rendered. That is solid endorsement of Thea's power when in the proper hands. Wow 👍
                                          • soloS
                                            solo
                                            Excellent stuff David,
                                            I ran it through Corel noise reduction.
                                            http://www.solos-art.com
                                            • 1 / 2
