    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    FluidRay RT - real time global illumination renderer
    extensions
    10 Posts 3 Posters 1.4k Views 3 Watching
    • F Offline
      fluid
      We are pleased to announce the release of a new version of FluidRay RT real-time global illumination renderer. This is a huge update. New features:
      • Spectral Rendering. The rendering is done now on a per wavelength basis, producing much more realistic results.
      • Node library and Drag&Drop: assigning materials to objects, changing environment lighting, etc. is now done thru a super simple drag&drop interface, all in real-time. Nodes can be added to the library using Drag&Drop as well.
      • IES lights, Spot lights
      • Blackbody and arbitrary spectrum illumination
      • Realistic Metals
      • Participating media
      • Video Tutorials to get started
      • Speed Improvements & Bug Fixes
      You can try FluidRay RT now by downloading at http://www.fluidray.com/downloads.
      You can find a series of FluidRay RT introductory videos at http://www.fluidray.com/help.
      Nicola
        Sorry but this is a Standalone ? A render Only for Sketchup? What is the file format that it can import ?...
        And that is commercial prog ?
        • F Offline
          fluid
          Yes, it is standalone and it will be a commercial product. We are in the beta phase, so only the demo is available for non-beta testers. You can import meshes and materials using the .obj file format.
          You can find a tutorial on how to import .obj files in FluidRay RT at http://www.fluidray.com/help
          • I Offline
            ilay7k
            Hello Nicola
            Why do you still support only Intel CPU?
            I have amd and can't start your app at it.
            • F Offline
              fluid
              We just released FluidRay RT 0.7.1 featuring:
              -Improved compatibility with AMD processors and video cards not supporting multisampling
              -Sun-Sky procedural environment
              -Up to 25% speed improvement
              -A bunch of bug fixes
              As usual, you can grab the demo from the download page: http://www.fluidray.com/downloads
              Cheers,
              Nicola
              • F Offline
                fluid
                Hi All,
                We just released FluidRay RT 0.7.2 featuring:
                -Bump mapping
                -Fixed HDRI enviroment map scale issue
                -Fixed text fields enter issues in the Attribute Editor
                -Obj import now also imports textures and bump
                -FluidRay RT x64 now installs in the “Program Files” and not in “Program Files (x86)”
                -A bunch of other bug fixes
                • F Offline
                  fluid
                  Just released FluidRay RT 0.7.3 featuring:
                  -Procedural Textures
                  -Improved UI
                  -Bug fixes
                  • Nicola
                  • F Offline
                    fluid
                    Just added a new video tutorial on how to organize the scene using containers. You can check it out here:
                    http://www.youtube.com/watch?v=qo9zB28ikII
                    Nicola
                    • F Offline
                      fluid
                      Hi All,
                      We just released FluidRay RT 0.7.4 featuring:
                      -Instancer nodes
                      -Adjustable filter size
                      -Bug fixes
                      You can grab the demo here: http://www.fluidray.com/downloads
                      Here are a couple of renderings done with the latest version of FluidRay RT:
                      http://www.fluidray.com/wordpress/wp-content/gallery/posts/car5.jpg
                      http://www.fluidray.com/wordpress/wp-content/gallery/posts/meadow1.jpg
                      You can find more sample renderings in the gallery: http://www.fluidray.com/gallery
                      Also, we added some sample scenes that can be found in the download page as well.
                      • Nicola
                      • F Offline
                        fluid
                        We just released a new FluidRay RT video tutorial on the material and model library, showing how to edit materials and other scene elements in real-time:
